2012 2.2 fwd slight hesitation down low
Postby Ken205 » Wed Jul 11, 2018 3:35 pm
Any one able to help
Slight hesitation down low only in traffic.
Feels to me like a lack of fuel for a split second.
Also sometimes it will cut out just after starting bit will start straight away the second time. Injectors tested and perfect. Anyone with any ideas
Ken205
Re: 2012 2.2 fwd slight hesitation down low
Postby knobby1 » Wed Jul 11, 2018 11:57 pm
Ken205 wrote:Any one able to help
Have you had the codes read..??
Postby andz327 » Thu Jul 12, 2018 1:30 am
+1 for codes
Whens last time fuel fiter was changed ? ((USE GENUINE F/F))
How did they do the check on your injectors ?
andz327
Postby knobby1 » Thu Jul 12, 2018 3:28 am
Is it Euro-4 or Euro-5..??
Postby Ken205 » Thu Jul 12, 2018 8:35 am
No codes read yet will do it tomorrow
New gen fuel filter used
Injectors tested properly for everything with a printout for each one
How can I tell if it's euro 4 or 5
Ken205
Postby andz327 » Thu Jul 12, 2018 9:07 am
Ken205 wrote:No codes read yet will do it tomorrow
What's your reg num ?
andz327
Postby knobby1 » Thu Jul 12, 2018 10:48 am
Ken205 wrote:How can I tell if it's euro 4 or 5
Is the badge on the left rear door blue or red..??
Postby Ken205 » Thu Jul 12, 2018 11:46 am
No badge can I tell from the engine
2.2 fwd
Big dpf on exhaust
Ken205
Postby Ken205 » Thu Jul 12, 2018 11:57 am
2.2 fwd
Big dpf on exhaust
Ken205
Postby Steve192 » Thu Jul 12, 2018 5:36 pm
If it’s a 2012 2.2 it should be euro 5. They came in at about 61 plate I believe. Mines a 62 plate 2.2 and it’s a Euro 5. If it’s got a dog it’s defo a Euro 5.
My van had pretty much the same issue, judderig etc low down revs. I found that the gasket in my egr valve looked like it was leaking. I took it apart and cleaned the gasket off, cleaned both sides of the egr up and applied some instant gasket in between. Fingers crossed it hasn’t happened since and seems to run quieter.
Steve192
Postby Ken205 » Fri Jul 13, 2018 9:06 pm
Just back from garage and one or two fault codes showing
1 p0098
2 p0113
3 p0193
4 p2291
5 p0045
6 p2564
7 p02e9
8 p02e0
9 p26a2
Some might be since an engine rebuild so cleared them all so we'll wait and see
It seems to happen at exactly 1500 rpm in every gear when coasting and just giving it light throttle.
If you floor it it doesn't happen at all
Ken205
Postby Ken205 » Fri Jul 20, 2018 10:03 pm
Cleared stored codes last Friday
After doing 500 miles this week and no codes showing
There was a slight hole in the pipe going from inlet manifold to intercooler but replaced it this evening and no change
Would it be anything to do with me driving with my foot on the clutch pedal
Ken205
Postby andz327 » Fri Jul 20, 2018 10:49 pm
If you give me your reg I'll check on etis if it E4 or E5 in case your not sure
andz327
Postby Ken205 » Fri Jul 20, 2018 11:26 pm
Irish van
Will Irish reg do or chassis no.
Ken205
Postby andz327 » Fri Jul 20, 2018 11:34 pm
I'll try both
andz327
