mk7 2007 2.4 prv
mk7 2007 2.4 prv
Postby raybe » Sun Jul 29, 2018 4:31 pm
Hi people ive been having starting problems,but once started been running ok
idle is not great but ive got away with it for last few weeks,and today fitted a new pressure sensor on the front rail.
no change,so i took off the rail and found prv,in bits,so i replaced with new one.
now when it starts it idles better sits at 8000 rpm,and dont cut out like before,only when i drove it up the road it seems to have now lost power.
is this gonna be just a matter of pcm,and prv reset etc.and will it be safe to drive to fords about 3 miles away.many thanks.
raybe
Re: mk7 2007 2.4 prv
Postby motorman116 » Sun Jul 29, 2018 6:43 pm
Its normally the suction control valve (fuel metering Valve) on the back of the fuel pump that causes the Pressure Relief Valve to blow....
2008 3.2 5 pot diesel Ford Transit GLX Lwb, Hr
motorman116
Postby raybe » Sun Jul 29, 2018 7:25 pm
yeah ive heard this ,i reckon i'm wasting time,getting it learned if the scv is knackered.i was just hoping it was only prv that had gone.but then i won't know until it's been learned or go`s bang later.
where is the best place to buy the scv,ford said £163
or are these cheaper ones on ebay ok ??
raybe
Postby andz327 » Sun Jul 29, 2018 7:26 pm
Get the learns done, but if prv isn't genuine it's probably your less power problem and more than likely learns wont complete
andz327
Postby andz327 » Sun Jul 29, 2018 7:29 pm
Prv and scv need to be proper genuine mate, forget ebay prv's try PF JONES
andz327
Postby raybe » Sun Jul 29, 2018 11:58 pm
hi many thanks.
im gonna buy a genuine part tomorrow ,could i do the learn myself, if i buy a ford scanner,or would i need a real expensive one,also anyone know is it an easy process,just out of interest,what price scanner would i need.many thanks.
raybe
Postby andz327 » Mon Jul 30, 2018 12:17 am
raybe wrote:hi many thanks.
Was your prv out of Ford ??
andz327
Postby knobby1 » Mon Jul 30, 2018 10:34 am
raybe wrote:now when it starts it idles better sits at 8000 rpm,.
I do hope she's not idling at 8000rpm.. :lol: :wink:
Genuine SCV & PRV are the only way to go...or you'll be buying them again. Counter reset and a full set of learns is then required. The PRV has blown because of a faulty SCV.
Forscan with a modified ELM-327 or IDS for doing the learns.
Postby raybe » Mon Jul 30, 2018 3:46 pm
Hi thanks guys ok today i ordered prv genuine ford,£118 as last one was cheap ebay type.no good.
ive also ordered a denso scv from rf jones,56 delivered.if what i got on my transit is denso as the ford numbers cross to, i guess im buying the genuine part just not in ford box at £200
sorry the 8000 was 800 lol.
what price should i be paying for the Counter reset and a full set of learns ford reckon 1-3 hours at £114 per hour.
and if i do buy a Forscan with a modified ELM-327 or IDS ,what sort of price are they,and is it easy to do.???.many thanks.
raybe
Postby knobby1 » Tue Jul 31, 2018 1:13 am
raybe wrote:Hi thanks guys ok today i ordered prv genuine ford,£118 as last one was cheap ebay type.no good.
Learns only take ~45 mins to do...Forscan is free to download the "Windoze" version and the modified ELM-327 can be had for ~15quid-ish.
Postby raybe » Fri Aug 03, 2018 9:21 pm
hey guys thanks for all your help,just thought id come back and say.all is good ,well so far.
fitted genuine ford prv,£120 and scv from pf jones original denso,??,-£58- i say that as there not stamped denso.
took all your advice,and got the forscan,ebay £17-run it all up tonight,was a little worried as not used many scanners but done loads of mechanics over the years. so fitting it all was very easy.
anyway with a bit of panicking it all learned ok,and truck pulled up the road nice.
i have a couple of codes still,but there for other things,i think i need to change a battery,will test it proper tomorrow.many thanks.
raybe
Postby karl » Sat Aug 04, 2018 4:00 pm
raybe wrote:hey guys thanks for all your help,just thought id come back and say.all is good ,well so far.
they are not stamped denso from pf jone but the one i got the other day was a nissan one and works a treat
you can tell fake from genuine ones by looking at the size of the hole at the end of the scv
karl
Tranny Lover!!!
Postby karl » Sat Aug 04, 2018 4:02 pm
I put it on this van I didn't do the prv as it wasn't blowen and a genuine part https://www.facebook.com/www.automotive ... =3&theater
karl
Tranny Lover!!!
