Smokey transit
Smokey transit
Postby mickd250 » Mon Aug 06, 2018 7:28 am
if got a 2009 2.2 85psi transit what is throwing out loads of black smoke on acceleration and it is down on power , the problem started of intermiten but now it is there all the time.
only codes what is coming up is about the her valve witch has been blanked of, there is no splits in any turbo/intercooler hoses it has had a new map and maf sensor witch made no difference .
if egr is dodgey but blanked of would this make the van smoke is my main question , if not what else could it be
van starts and ticks over fine .
it also had new turbo and is not using any oil thanks
mickd250
Re: Smokey transit
Postby gotgcoalman » Mon Aug 06, 2018 3:49 pm
have you taken the intercooler pipes off and checked for excessive oil residue build up?
Too bloody quiet :shock:
gotgcoalman
Re: Smokey transit
Postby mickd250 » Mon Aug 06, 2018 5:55 pm
just had a look there all looks good and clear
mickd250
Re: Smokey transit
Postby gotgcoalman » Mon Aug 06, 2018 9:49 pm
Can you check the boost psi of the new turbo?
gotgcoalman
Re: Smokey transit
Postby mickd250 » Fri Aug 10, 2018 2:42 pm
intercooler is fine and turbo is boosting good just loads of smoke any other ideas ,also every now and a gain when it is down on power it knocks a little bit just like a diesel knock
mickd250
Re: Smokey transit
Postby mickd250 » Sat Aug 11, 2018 5:10 am
any more ideas , is it worth changing the egr valve even tho it's blanked off
mickd250
Re: Smokey transit
Postby mickd250 » Wed Mar 20, 2019 10:00 am
still got this problem if anybody can help, it has recently had 2 new injectors (the other 2 tested ok)
dont think turbo is boosting as much as it should but smoke it there even at low rmp,
van starts and ticks over fine anybody have any ideas thanks
mickd250
Re: Smokey transit
Postby knobby1 » Wed Mar 20, 2019 10:22 am
mickd250 wrote:still got this problem if anybody can help, it has recently had 2 new injectors (the other 2 tested ok)
Have you done the learns after fitting new injectors..??
Re: Smokey transit
Postby mickd250 » Wed Mar 20, 2019 10:35 am
yes , the lad said it took a few goes to do the pilot but he managed to get it done
mickd250
Re: Smokey transit
Postby knobby1 » Wed Mar 20, 2019 10:48 pm
mickd250 wrote:yes , the lad said it took a few goes to do the pilot but he managed to get it done
If it passed "ALL" the learns "successfully", it should be fine....if it's still blowing silly amounts of black smoke, I'd be a bit suspicious.
