Rear cargo lights won’t work
Postby Scott weaver » Sun Aug 12, 2018 3:53 pm
Hi there I’m new to the forum done a bit off searching and can’t seem to find anything
I’ve got a mk8 2018 transit it’s the 2.0l 170 ps my rear cargo lights stoped working and can’t seem to find the fuse for them and there’s nothing in the manual well the pre fuse board is meant to house the fuses and relays for the interior lights but the relay section on the pre fuse box board isn’t fitted to my model
Any help would be
Greatful
Scott
Scott weaver
Re: Rear cargo lights won’t work
Postby loot » Sun Aug 12, 2018 8:01 pm
F25 and f32 for interior lamps, that's for the custom not mk8 I have no idea if they are the same but have a look anyway :-)
07 350 170ps
Ids map here
loot
Postby Scott weaver » Sun Aug 12, 2018 9:39 pm
I’ve checked all fuses both fuse boxes under the steering wheel and also engine compartment fuse box and can’t seem to find a blown fuse any where that’s what’s getting to me
Scott weaver
Postby loot » Sun Aug 12, 2018 10:16 pm
My rear cargo bulb doesn't light up and I'm thinking the bulb has blown, next thing will be to meter the lamp connector to see if there's power.
07 350 170ps
Ids map here
loot
Postby Scott weaver » Mon Aug 13, 2018 6:47 am
Already done that an have haven’t got any power to none off the lights
Scott weaver
Postby ned » Mon Aug 13, 2018 8:54 am
Is the mk8 the same as the mk7 where the load light is controlled by the cab light?
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby Scott weaver » Mon Aug 13, 2018 9:32 am
I’m not to sure the cab light still works just haven’t got nothing in the back
Scott weaver
Postby millymat » Sun Oct 25, 2020 5:09 pm
Scott weaver wrote:I’m not to sure the cab light still works just haven’t got nothing in the back
Hi, did anyone manage to sort this as my rear cargo lights have stopped working and it’s driving me nuts, thanks
millymat
