Ad built data for bcm help needed ASAP
Postby reaperkinqs » Thu Aug 16, 2018 8:53 pm
Not shore if this is the right placed sorry if it ant
HI all i need the as build data for my a transit im working on its a 2.2 trend where can i get it from.
i have a vxdiag vcx nano running ids 109.1 can i connect it to internet and let the ids get the data for me Help needed asap
thanks in advanced
reaperkinqs
Re: Ad built data for bcm help needed ASAP
Postby Airthies » Thu Aug 16, 2018 10:59 pm
Somewhere on the motorcraft site it always takes me a bit of searching to find it can't remember exactly where.
Have a look yourself there should be a section you can put in your vin and download it for future reference.
https://www.motorcraftservice.com
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby reaperkinqs » Sun Aug 19, 2018 7:42 pm
Airthies wrote:Somewhere on the motorcraft site it always takes me a bit of searching to find it can't remember exactly where.
hi cheers mate i have got it now just having problems programming the bcmii now it keeps failing and even when i try to load as built data on car parameter it fails on ccf mast module now it failed my abs light stays on and traction do u have any idea what it could be im useing ids 109.1 with Vxdiag Vcx Nano think i need a vcm2
reaperkinqs
Re: Sliding door contacts not working
Postby Airthies » Sun Aug 19, 2018 11:02 pm
Even with clone IDS VCM11 & v86.04 it usually shows failed notifications for a couple of set points in the process but always works anyway. Not done it with the higher versions or nano sorry
V86+patch
V86.04
X-Prog
C81
Airthies
Postby reaperkinqs » Mon Aug 20, 2018 1:39 am
Airthies wrote:Even with clone IDS VCM11 & v86.04 it usually shows failed notifications for a couple of set points in the process but always works anyway. Not done it with the higher versions or nano sorry
ok cheers for the info mate i can say it dont work with the nano tryed like 10 different vehicle same error ever time
reaperkinqs
