NO IGNITION - RADIO STILL WORKS
Postby landscaperdave » Thu Aug 16, 2018 10:13 pm
FIRST POST ON FORUM & LOOKING FOR SOME ADVICE ON MY 1995 TRANSIT TIPPER (127,000 MILES). BEEN USING EVERY DAY FOR LANDSCAPING WORK & SOMETIMES RECENTLY DIDN'T START TIL 2ND TURN OF KEY BUT GENERALLY A GOOD RUNNER. ON SITE YESTERDAY AND TRIED TO START BUT GAVE OUT A FIZZING SOUND (NO BURNING SMELL THOUGH) FOR A FEW SECONDS THEN ALL IGNITION LIGHTS WENT OUT & NO HOPE OF STARTING BUT COULD STILL TURN RADIO ON. CHARGED BATTERY (FORD) OVERNIGHT & TRIED TO START AGAIN THIS MORNING & SAME THING HAPPENED. TOOK BATTERY TO BE TESTED - APPARENTLY ON ITS LAST LEGS - GOT NEW ONE AND TRIED AGAIN - GUESS WHAT!! SHORT FIZZ AGAIN THEN ALL IGNITION & DASH LIGHTS GONE BUT STILL HAVE RADIO & CENTRAL LOCKING. CHECKED ALL COLOURED (SEE-THROUGH) FUSES WITH NO OBVIOUS ONES GONE - ANYONE KNOW WHICH OF THE CHUNKY BLACK ONES MIGHT BE RELEVANT? ONLY OTHER BITS OF INFO THAT MIGHT AFFECT THINGS ARE FAULT ON DRIVER'S HANDLE - WILL LOCK ON KEY FOB BUT WON'T OPEN FROM OUTSIDE & OLD OIL LEAK MEANS A REGULAR FILM OF OIL OVER ENGINE BLOCK.
CHEERS FOR ANY ADVICE
DAVE
landscaperdave
Re: NO IGNITION - RADIO STILL WORKS
Postby knobby1 » Fri Aug 17, 2018 4:01 am
You don't have to shout at us... :wink:
Postby Altransit » Fri Aug 17, 2018 11:39 am
Sounds like one or more of your glowplugs has gone short circuit, and is robbing power from the starter motor. Check to see if the fusible link near to the jump start point has burnt out.
Remove the glow plug relay and try starting it again :idea:
Postby landscaperdave » Sun Aug 19, 2018 3:40 pm
Many thanks for advice - sounds like a strong possibility.
Cheers
Dave
landscaperdave
Postby Jay2018 » Sun Aug 19, 2018 6:43 pm
Could this possibly be some kind of ignition barrel problem?
2012 MK7 Transit Trend 125 T350 6 SPD FWD MWB MR (Frozen White) :D
2010 MK7 Transit Jumbo 100 - SOLD :(
Galant VR4 8th Gen Type S(TT), 300ZX(TT) + S14A(T), Supra MK3(T), Golf MK4 1.8(T), GS300 & Civic EG9 VTI (ALL SOLD)
Jay2018
Postby knobby1 » Mon Aug 20, 2018 11:49 pm
Jay2018 wrote:Could this possibly be some kind of ignition barrel problem?
The ignition "switch" often gives trouble...not the barrel itself.....the switch lives on the back of the barrel...cheap and easy to replace.
However, it's not really related to the glow plugs....it supplies power to all systems.
Postby bambi mk 1 » Sat Aug 25, 2018 8:37 pm
Altransit wrote:Sounds like one or more of your glowplugs has gone short circuit, and is robbing power from the starter motor. Check to see if the fusible link near to the jump start point has burnt out.
1995 with glow plugs must be an early prototype mk6 Al :mrgreen:
bambi mk 1
Postby Altransit » Sun Aug 26, 2018 12:38 am
:P :P Ah, I was just checking to see if anyone was listening, honest :oops: :P
I actually missed the 1995 bit, with all the shouting going on :roll: :mrgreen:
Postby Altransit » Sun Aug 26, 2018 12:39 am
landscaperdave wrote:Many thanks for advice - sounds like a strong possibility.
Cheers
Dave
Bad advice, sorry, I misread your post and thought you had a Mk6 :oops:
