Cheers Lootloot wrote:Either fault find the break in the cable between the wear sensors or bridge speedo pins 15 and 18 to disable it permanently.
I found that it breaks at the drivers side rear connector on the axle but can break anywhere along the 4 wheels connectors.
It is basically 1 wire that goes from the speedo to all 4 wheels then back to ground and when there is a break then the speedo sees open circuit and turns the warning lamp on. Very simple setup
Users browsing this forum: metalworker0, simonwood
