FredTransit wrote:That's a core plug. May be it needs replacing.
MrMPuk wrote:Just knock the core plug out and out a new one in with a bit of Hylormar on it.
jamieo wrote:Core plugs are easy to change and are very cheap.
EDIT: The last core plug that I changed was on a capri about 8 years ago and it only cost 47p from a ford dealers.
Nighthawk wrote:are you sure thats where the leak is?
the water pipe can get a tiny hole in it and put a fine spray onto the exhaust manifold, that'll evaporate and make it look steamy in the area without soaking things.
gardener68 wrote:Nighthawk wrote:are you sure thats where the leak is?
the pipe on my van got a hole where it goes round the back of the rocker cover.
real tricky to suss out because the water leaked out and ran back along the head gasket joint to the front of engine and made steam everywhere.
smear some grease or similar round the coreplug and if it gets blown away then thats where the leak is.
motorwise wrote:Nighthawk wrote:are you sure thats where the leak is?
I agree, the stains are clearly on top of the manifold and the core plug doesn't look corroded at all - check the heater hose above it thouroughly
