by Smooth Hound » Fri Aug 17, 2007 5:36 pm
i was referring to the fuel filter, that might be worth a go , cant do any harm anyway.
you mentioned that you have put this pump on your van off another one, i am presuming then that your last pump packed in, what were the symptons that made you think or know it was the fuel pump that was your problem, could you go through as to what happened from the beginning beefore you changed the pump,
'94 L Reg 2.5Di LWB high top
