by Bill Bourke Special » Sat Aug 12, 2017 4:55 am
Thanks for your help, here's some more,
I managed to get Passenger side blinker by pulling strait out and using the end of a scraper to pop the spring off, then removed the top screw of the plastic grill/light surround with a right angle screwdriver. you might get a normal one in on the angle but if you have a bent screwdriver, use that. So, now attempt to remove headlight. The outside top bolt, if you have a close look, has a thin nut on your side of the panel where it threads into the back of the light pod. Simple terms, you don't have to put a deep socket from behind, just use a thin 14mm open ended spanner from the front. Headlight partly removed, slide your arm in and your nearly home, find the lever and push.
Once its open, then you can see how a long thin stick, or screwdriver would work!!! Locate the vertical upright support on the motor side of the radiator, its left of center about where the idler pulley is. OK, now the "ideal" would be 8mm H/T pointed steel rod. Slide the rod up, resting it on the face of this vertical support/bracket as you go, but on the passenger side edge of it. The rod should stop when it hits the bonnet, and you should be up against the release lever. Push toward the Driver side, the lever has about 1" of travel, about the same as the width if the vertical support. The pointy bit is probably required to help slide beneath the plastic flap and the radiator. Hope this helps
