Airbag Light - Mk6
Airbag Light - Mk6
Postby davemfox » Thu Oct 25, 2007 1:34 pm
Hi,
My 75 PS Mk6 has a flashing airbag light. It does 5 flashes then has a 4 second gap then does another 5 flashes etc.
Does anyone know what this means?
Thanks,
Dave
2011 140 PS 260 SWB Tranny
1993 YZF 750SP
davemfox
Re: Airbag Light - Mk6
Postby Dan T » Fri Oct 26, 2007 12:44 am
Mine does it too :evil:
Bought the van without the airbag bulb in clocks (was assured it was in full working order) :arrow: replaced the bulb at a cost of £14 :arrow: b*stard just flashes :arrow: removed it :roll:
It dosen't solve the problem but it no longer drives me up the wall :D
Dan T
Postby Nighthawk » Fri Oct 26, 2007 9:32 pm
Hi m8
Can you re check the flash code?
There is NO published reason for flash code of 54.
Check all the the fuses, to ensure that there isn't one in the wrong place.
The other possible is that the crash memory of the module is full and it's flashing out any old twoddle, if this is the case the only cure is a new restraint control module.
Transit.........Job done
Nighthawk
Postby davemfox » Sat Oct 27, 2007 11:21 am
All fuses are in the right place and have not broken.
The flash sequence is definitely 5 on and then a 4 second break (could be a 5 second break as it is actually 4.5 secs).
Do you have the part number for that module as my local Ford place couldn't it?
Dave
1993 YZF 750SP
davemfox
Postby Nighthawk » Sat Oct 27, 2007 6:36 pm
I misread your opening post :oops:
All flash codes on 2000 -> transit are 2 digit.
Please advise as to exactly what the light is doing
ignition on.....light on constantly for 5 secs, then 1 flash ...2 sec light off......5 flashes in succession
that would be code 15, meaning that the drivers air bag is shorted
but there is also a 35 which means that the passenger airbag resistance is low.
Before you say you don't have a passenger side bag, the wiring is there with a special resistor fitted into the plug near the fuse box behind the dash.
Nighthawk
Postby davemfox » Sun Oct 28, 2007 11:28 am
Ok, ignition on all idiot lights come on and glow for a second or so, engine starts then approx. 17 secs later the airbag light goes through it's flashing sequence.
Here is a video that I shot of it....
http://www.mediafire.com/?5u4m23p0jzl
Dave
1993 YZF 750SP
davemfox
Postby Nighthawk » Sun Oct 28, 2007 8:41 pm
You need to get this vehicle on to IDS
The airbag system is fubar !
The system should light the SRS warning light constantly for 5 seconds or so after the ignition has gone on, Your's isn't doing that.
The flashes also look too long.
Nighthawk
Postby davemfox » Mon Oct 29, 2007 1:02 pm
Ok, thanks for your help. Will get it onto IDS shortly...
Dave
1993 YZF 750SP
davemfox
Postby davemfox » Tue Oct 30, 2007 12:54 pm
Nighthawk wrote:I misread your opening post :oops:
Ok - I tried something different today :mrgreen:
I took all the idiot light bulbs out of the dash and reseated them. Guess what?!?! That light flashing sequence has now gone and the SRS light stays on for the length of time it is supposed to, and then it gets into the flashing sequence of - three flashes, a break and then two flashes...
Again the video link is here (it's a smaller video this time :wink: ) - http://www.mediafire.com/?9hkltymiu4l
So what does that mean then?
Dave
1993 YZF 750SP
davemfox
Postby davemfox » Sat Nov 10, 2007 5:45 pm
Nighthawk - did you have a chance to look at this? Any ideas on what it is and what I need to buy to fix it?
Cheers,
Dave
1993 YZF 750SP
davemfox
Postby Nighthawk » Sat Nov 10, 2007 11:36 pm
sorry m8, had a hectic week and have only just found this again.
32 is a high resistance in the clock spring assembly.
Thats going to need a new one I'm afraid. Removing the Air bag assembly from the steering wheel CAN be a dangerous operation.
You need to ask your local ford parts dealer for a clock spring.
Fitting ......
Put the road wheels in the STRAIGHT AHEAD position
disconnect the battery and go for a brew
remove the 2 plastic covers from the rear of the steering wheel to allow access to the air bag fixings, remove these bolts and pull the air bag away from the steering wheel. Disconnect the air bag and horn wiring.
store the air bag in the REAR of the van with the ford badge UPWARDS
remove the grey covers from the steering lock housing and disconnect the 2 multi plugs from the base of the housing (look at those on the new part)
Disconnect the switches by pressing the release tabs and pushing the switches upwards, you can leave the wiring in place
Now remove the steering wheel, undo the center bolt 3 turns and grasp the steering wheel and 3 and 9 and pull the wheel firmly, they are usually quite tight, so give it a good pull and try 6 and 12 too, in some cases a puller is needed !
Once it's loose remove the bolt and put the wheel to one side.
the clock spring is secured to the steering lock housing with small tabs, lever these and it'll come away.
Fit the new assembly and ONLY then should you break off the RED centering tab
rebuild in reverse order really, making sure that the steering wheel goes back on it's MASTER spline and that the bolt is tight.
Hope it helps
NH
Nighthawk
Postby davemfox » Sun Nov 11, 2007 12:42 pm
No worries mate and thanks for the advice...will let you know how it goes
Dave
1993 YZF 750SP
davemfox
Postby Dan T » Sat Apr 26, 2008 10:32 pm
davemfox wrote:No worries mate and thanks for the advice...will let you know how it goes
Dave
Did it solve your problem ?
Dan T
Postby davemfox » Thu May 01, 2008 4:01 pm
Dan,
Thanks for the follow up. I've not fitted it yet, but will be doing so shortly :oops:
Will let you know how I get on 8)
Cheers,
Dave
1993 YZF 750SP
davemfox
Postby davemfox » Sat May 03, 2008 3:34 pm
Ok fitted it this afternoon.
Those instructions are spot on :lol: , and fingers crossed it seems to have cured the problem
Dave
1993 YZF 750SP
davemfox
