Idle problems
Re: Idle problems
Postby jay bur » Thu Nov 29, 2012 8:55 pm
Hi , ive been having these problems to, so im convinced its the pedal. or a sensor on the pedal. Do i need to buy the whole pedal assembely, at about 100 quid. ? And when i order it , do i just describe it as mk 6 transit accelorater pedal, or do i need to be more specific, Like model , or reg etc, Cheers
jay bur
Re: Idle problems
Postby ake » Fri Nov 30, 2012 4:16 pm
Yes, complete pedal assembly.
When you order give full details of you vehicle, I believe there are at least two different pedals
Re: Idle problems
Postby jay bur » Fri Nov 30, 2012 9:41 pm
Cheers good buddy, also , the problem has only started over the last week or so, and only happens every so often.Should i just go for it and swap the pedal, or should i wait for the problem to progress just to be sure? Although it does seem to match up with what everyone else has said. :?:
jay bur
Re: Idle problems
Postby ake » Sat Dec 01, 2012 9:58 am
The pedal will get worse and worse and eventually it will cause the engine to go into limp mode when it will not respond to the pedal at all.
Change it sooner rather than later
Re: Idle problems
Postby jay bur » Sat Dec 01, 2012 7:45 pm
Cheers mate. Will do :D
jay bur
Re: Idle problems
Postby SteveRSF » Wed Apr 16, 2014 6:53 pm
Guys had similar too....... Van was ticking over taking to a mate for ten mins went to pull away noticed a lack of power then nothing....... I could put the pedal to the floor...... But engine was on tick over turned him off back on it was fine
Then last night was outside shop for two minutes got home a mile away and van was stuck on high revs on tickover turned him off again back on they were fine
This the peddle then?
Steve
SteveRSF
Re: Idle problems
Postby ake » Wed Apr 16, 2014 7:11 pm
SteveRSF wrote:Guys had similar too....... Van was ticking over taking to a mate for ten mins went to pull away noticed a lack of power then nothing....... I could put the pedal to the floor...... But engine was on tick over turned him off back on it was fine
Steve
Sounds like it to me
