Engine wont run when cold
Postby Bully » Sat Mar 29, 2008 12:44 am
I have s plate ex bt 120swb transit 2.5
Problem is engine will not run when cold. I can start it but then it just cuts out! Runs as normal when warm!
Have checked fuel and air filters etc and have had the injectors checked out....all ok. It has been sugested that it might be the pump?
Any sugestions would be helpfull.
cheers.
Bully
Re: Engine wont run when cold
Postby MrMPuk » Sat Mar 29, 2008 12:49 am
Defective cold start, will it run once you've sat with with you foot on the throttle for a couple of minutes.
Postby Bully » Sat Mar 29, 2008 1:02 am
yes!
Bully
Postby MrMPuk » Sat Mar 29, 2008 1:04 am
Well I've had many Mk5s now and every single one has been the same. I'd just live with it if I was you.
Postby Bully » Sat Mar 29, 2008 1:10 am
Had a feeling that might be the case..........Think thats what il do!
Cheers for your comment! At least its not that serious then!?
Bully
Postby vanfox » Sat Mar 29, 2008 6:13 pm
I had this on my R reg Di. I borrowed the butterfly link of it for my other Di, then it wouldn't even run.
(Butterfly closed).
I strapped the butterfly open, now it idles almost from cold, worth a try?
vanfox
Postby Smooth Hound » Sat Mar 29, 2008 6:18 pm
it would still have the problem when warm if the butterfly wasnt opening, i recon the cold start myself, the weathers warming up, it wont be a problem soon :wink:
'94 L Reg 2.5Di LWB high top
Smooth Hound
Postby transitrust » Sun Mar 30, 2008 2:09 am
i have the same problem with my v reg
now my mk3 g reg cold as you like turn of the key and off you went wish i still had her but i still think the mk5 looks a bit better but i like all transits
FORD TRANSIT THE HEART OF ENGLAND
transitrust
Postby Jchar » Sun Mar 30, 2008 4:03 pm
I have a 2002 125 Hp with the same problem. I´m getting used to it because it has the problem since i´m driving this vehicle (2004). Of course, Ford dealers allways tell me i´m the only one with this problem. Would be nice to now if there´s somebody around who has the problem solved. At first i thought it would be engine oil with the wrong viscosity, but after changing the oil it did not improve.
Jchar
Postby Pakmoto » Sun Mar 30, 2008 10:46 pm
My 97 R mk5 80swb is the same, but a little pressure on the gas pedal for 10 seconds sorts it.
Ah Luv Wheelies Me!!!
Smoggy born and inbred
Pakmoto
Postby Altransit » Mon Mar 31, 2008 12:01 pm
Mine was like it until I fitted a new timing belt :wink:
Starts and ticks over with no throttle now :wink:
