I`ve got the normal mk5 problem of the fan switch only operating on speed 3 which I believe means the heater resistor is kaput - thing is every now and then speed 3 wont work either unless you wiggle it then it works, I suppose that might mean I`ve got two problems, the resistor and the switch?
Does anyone know how to test the resistor and what the resistance should be?
