2005 2l tdi engine fit into a 51 plate 2litre van???
Postby bigbazsparky » Mon Dec 29, 2008 11:49 am
hi guys think my engine nakered seen one on flea bay but its from a 2005 model and my van is a 51 plate both front wheel drive both 2 litre tdi will it fit???
its sold with gear box and fuel pump wondered if it wil go str8 in and is it a big job???
thanks for any advice
bigbazsparky
Re: 2005 2l tdi engine fit into a 51 plate 2litre van???
Postby AndyG » Mon Dec 29, 2008 4:56 pm
There's quite a bit to consider here I think :!:
If you can transfer your fuelling system ie; pump (injectors, if different output) etc....... you should be fine :!:
The transmission/axle may have to be swapped out too as there has been talk on here that the splines are different from the early ones compared to the later ones :roll:
It would be better to have the complete donor TBH :!:
At least you then have all the bits including ECU and wiring :wink:
With any luck, someone will come along that has done this and shed some more light on the matter :D
Postby bigbazsparky » Mon Dec 29, 2008 5:31 pm
engine and gear box come complete with injectors and fuel pump so was hopin it would go straight in but then again im no mechanic so no idea.
just lookin for anyone that maybe swapped one before
engine and box goin v cheap on ebay so could have been cheaper than takin it into garage to see wots up with mine
cheers for advice so far
bigbazsparky
Postby AndyG » Mon Dec 29, 2008 5:36 pm
Can you have the ECU and key too :?:
Is the wiring available, as knowing Fords, things like sensors move around the bay :!:
Postby bigbazsparky » Mon Dec 29, 2008 5:37 pm
dont no about ecu and wiring is it needed???
looks like takin mine into garage see if its not something too expensive hopefully
bigbazsparky
Postby bigbazsparky » Mon Dec 29, 2008 5:39 pm
this is engine n box dirt cheap i think comes wi fuel pump too
if no good for me maybe bargain for one of u guys
.co.uk
bigbazsparky
Postby AndyG » Mon Dec 29, 2008 5:48 pm
What's yours doing :?:
Like I've already said, you can swap over bits from yours :!: :wink:
Postby bigbazsparky » Mon Dec 29, 2008 5:51 pm
engine started knocking bigtime then lost power n died. recently had second hand fuel pump fitted so maybe could be something to do with that i guess but im crap wi cars n vans can wire ya an house no problems lol
bigbazsparky
