Etis lookups
Re: Etis lookups
Postby AndyG » Tue Jan 13, 2009 11:21 pm
Dan T wrote:
Andyg wrote:The bit you left out :!: :lol:
Minor Features
The known minor features of this vehicle:
* With Front Mudflaps
* Base
* Southampton Plant Built
* Marketing Level 4
* Less 2nd Row RH Side Window
* Less 2nd Row LH Side Window
* Less 3rd Row RH Side Window
* Less 3rd Row LH Side Window
* Less Rear Compartment Trim Panel
* Flr Cvr-Rubber Ins-Extended
* With Door Map Pocket
* With Front Roof Grab Handle
* Large Head/Long Arm Mirror
* Passenger Lrg Head/Long Arm Mirror
* With Drivers Seat Armrest
* With Front 2 Way Headrest
* With Driver 6 Way Mnl.Seat Adjuster
* With Rear Tow Hooks
* With 3 Point Seat Belts
* With Driver Air Bag
* Any Brand Tyre Vendor
* With Wheel Hub Cap
* Cold Start -10 Deg C
* With High Centre Of Gravity Pack
* With Sngle.L/B Dvr/Dual L/B Pass.St
* With Fresh Air Heater
* With Power Steering(Fixed Ratio)
* With MPH/KMH Speedo
* With Analogue Clock
* With Engine Immobiliser
* With Safeguard Anti-Theft Sys(Pats)
* 2000NT Series
* With Cigar Lighter
* With Roof Marker Lamps
Missed some :wink:
Minor Features
With Front Mudflaps
Base
Re: Etis lookups
Postby turboskinz » Tue Jan 13, 2009 11:22 pm
ill dig out logbook and get it off there many thanks for your attempt
2008 Sport van
2002 crewcab beavertail
1989 mk3 10 wheeler underlift
2000 ford Iveco 180e23 accident unit
2002 landrover discovery v8 on 22's
turboskinz
Re: Etis lookups
Postby fastmower » Wed Jan 14, 2009 8:22 am
Cheers guys - am I missing something glaringly obvious here - I can't see anywhere to put a reg number in? Would rather do it meself than keep troubling someone on here to do it for me!
Matt - no it's not mine mate - just one I've been looking at. Probably can't afford it though :(
Cheers everyone,
Andy
From four vans to two :-(
1997 Mk5 County Transit 4x4
2003 Mk6 ex RAC 330 SWB
fastmower
Re: Etis lookups
Postby dcwuk » Wed Jan 14, 2009 8:33 pm
You have to register first ( its free) then you click on vechicle and input your reg or vin no.
cheers
'I have opinions of my own -- strong opinions -- but I don't always agree with them.'
-George Bush
dcwuk
Re: Etis lookups
Postby sarndie » Thu Feb 26, 2009 12:47 pm
Any info on L202 TAH would be appreciated, I know the engine has been changed but am having trouble insuring it as I can't find out the model number/series like 80 or 100 etc.
sarndie
Re: Etis lookups
Postby alanwh » Thu Feb 26, 2009 1:57 pm
Engine: Diesel 2.5TI (115PS)
:shock: :shock: :shock:
Like hens teeth aren't they ?
alanwh
Re: Etis lookups
Postby MinorMatt » Thu Feb 26, 2009 4:04 pm
VIN Number: SFAEXXBDVEPA93608
Registration Number: L202TAH
Registration Date: 02.03.1994
Registration Country: GB
Primary Features
Build Date: 15.07.1993
Vehicle Line: Transit 92
Cab Style: Bus (M2)
Series: 115
Engine: OHC 2.0H
Transmission: 5-Speed Manual - MT75
Drive: RHD RWD
Axle Ratio: 4.56
Emission: EEC 5th Amendment Reduced Severity
Territory: (+)"GB"
Paint: Diamond White 73
Interior Colour: Slate Grey
Interior Fabric: Saturn
Apparently its a 115 (12 seater bus?) in Diamond white
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Re: Etis lookups
Postby sarndie » Thu Feb 26, 2009 4:43 pm
Thanks very much.
Pat.
sarndie
Re: Etis lookups
Postby mooncat » Thu Feb 26, 2009 5:54 pm
I have registered, how do you get the minor information..?? I have looked but cant see it anywhere,
cheers
http://www.askrestorations.co.uk
Most Northern Mini Restorer
mooncat
Re: Etis lookups
Postby MinorMatt » Thu Feb 26, 2009 7:27 pm
there is a "vehicle" tab which appears after you log in
93 L GL Minibus
Re: Etis lookups
Postby Rosso » Sun Apr 08, 2018 2:04 am
If can please check SA11 FFW as cant get diff ratio on etis via my iPhone !
Rosso
Re: Etis lookups
Postby paul2012 » Sun Apr 08, 2018 11:59 pm
Rosso wrote:If can please check SA11 FFW as cant get diff ratio on etis via my iPhone !
Transit 2006-2014, 2.4L Duratorq (85kW/115PS), Frozen White
VIN Number: WF0XXXTTFXBL40810
Registration Number: SA11FFW
First Registration Date: 31.05.2011
Type Approval Number (TAN): E1*2007/46*0248 / E1*2007/46*0264
Primary Features
Build Date: 18.05.2011
Vehicle Line: Transit 2006-2014
Cab Style: Regular Cargo Van
Series: 350M Series
Engine: 2.4L Duratorq (85kW/115PS)
Transmission: 6 Speed Manual Transmission-MT82
Drive: RHD RWD
Axle Ratio: 3.73
Emission: Stage IV Emissions
Air Conditioning:
Territory: (+)"GB"
Paint: Frozen White
Interior Colour: Lichen
Interior Fabric: Tomy (G-C)
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Re: Etis lookups
Postby Mac1984 » Mon Apr 16, 2018 12:25 pm
Hi Guys,
Could one of you be so kind and look up the details for
Following smiley?
WF0KXXGBVKTS89395
I've looked in etis myself but only a few info's come up, I'd like to find out as much as possible about its history.
Thanks a lot in advance
1996 2.5TD Bosch Mod, Bio degradable Body from factory but outlived its manufacturing plant.
Mac1984
Re: Etis lookups
Postby paul2012 » Mon Apr 16, 2018 4:20 pm
Mac1984 wrote:Hi Guys,
Following smiley?
WF0KXXGBVKTS89395
Build Date: 06.11.1996
Vehicle Line: Transit 1995-2000
Cab Style: Kombi Van (M1)
Series: 100S
Engine: Diesel 2.5T (85PS)
Transmission: 5-Speed Manual Transmission - MT75
Drive: LHD RWD
Axle Ratio: 4.56
Emission: 93 EEC Emission Requirements
Territory: (+)"D"
Interior Fabric: Interior Environment
This is all that is available
paul2012
Re: Etis lookups
Postby Mac1984 » Mon Apr 16, 2018 5:00 pm
Thanks Paul.
I thought it was maybe limited access in etis, as there is a button for more details but then it says not available at the moment, or something like that. It was a few months ago hat I have tried last, always the same result
Does the vin number tell where the vehicle was built? I was not sure if the GB in the vin means it's UK built or is that just coincidence?
Thanks for all the information.
Mac1984
