Fuel Primer
Fuel Primer
Postby duncmc » Wed Jan 14, 2009 11:53 pm
I am going to change my fuel filter in the next day or so, and does anyone know if the Sealey fuel primer will fit onto the Ford connectors? It is available at a Sale price of £11.44 at the mo, and I fancy that as a less messy way of getting air out than cracking injectors and cranking the engine. Cheers
http://www.sealey.co.uk/PLPageBuilder.asp?pageindex=1&gotonode=DoProductSearch&method=mProductSearch&IndividualTypeID=&productdescription=vs055&fulltextsearch=&category=0&requiredresults=10&cmdGo=Go%21
330SWB CD player. Remapped by Vantuner
duncmc
Re: Fuel Primer
Postby Guy88 » Wed Jan 14, 2009 11:55 pm
fill the filter first, mine has a manual pump on the filter aswell, all i did was fill mine and then pump the pump 20 or so times and away it whent
2008 200 T350, LWB GLX,
1999 SWB low roof ex BT, officially rotten and awaiting restoration
LIVIN' LOUD
Guy88
Re: Fuel Primer
Postby duncmc » Wed Jan 14, 2009 11:57 pm
Thanks for that Guy, I haven't looked too closely at the filter housing area yet. I just assumed it wouldn't have one judging by the discussions on here and from the TIS disc. It had a pollen filter by the way! :D
duncmc
Re: Fuel Primer
Postby duncmc » Thu Jan 15, 2009 1:37 pm
I don't think mine has a hand pump on it. :(
Is your pump ontop of the filter housing? I have a blanking plate that unscrews, allowing diesel to leak out.
duncmc
Re: Fuel Primer
Postby Guy88 » Thu Jan 15, 2009 6:15 pm
yea mines got a pump there, the 120ps ones had an electric one 8)
LIVIN' LOUD
Guy88
Re: Fuel Primer
Postby duncmc » Fri Jan 16, 2009 4:51 pm
Changed the filter this afternoon. Started and ran for about 30 seconds then died. As I didn't get a fuel primer (my local stockist didn't have one in!) I cracked the injectors as per previous posts, crancked engine, got rid of bubbles. But still won't start. Now batteries are flat due to sevral rounds of the above. Think I will put some more charge in the batteries and try again, or might try to jump start it?
duncmc
Re: Fuel Primer
Postby Guy88 » Fri Jan 16, 2009 6:29 pm
make sure the filters full
LIVIN' LOUD
Guy88
Re: Fuel Primer
Postby duncmc » Fri Jan 16, 2009 8:16 pm
Just had another go. Took filter back off to check. Was not full so filled back up. Have some charge in batteries now so cranked over 2 or 3 times. Still won't start. Took filter back off so still full. Next I am going to crack the injector pipes again. Is it best to do this whilst someone else is cranking it over, or straight after cranking whilst pressure still up? I will leave that until tommorrow now probably. :?
My other concern is its going to do this every time I change the fuel filter, so where can I get a priming device from? Or should I fit a fuel filter body/housing with a manual priming pump on like Guy's?
duncmc
Re: Fuel Primer
Postby Frag » Fri Jan 16, 2009 9:36 pm
If you fill the new filter before fitting it will start & keep running.......
Now its run dry,ensure filter`s full & battery`s charged.
Crank engine with all injector pipes open at injectors,as fuel start spraying everywhere lock them off.
Should fire up then......
Frag
Ford Technician
Re: Fuel Primer
Postby duncmc » Fri Jan 16, 2009 10:27 pm
Thanks Frag.
Reading on here and your post I now realise I have cocked up. :( I recon I thought I had filled it, but obviously not!!! :x So after a charge and in the daylight tommorrow I will give it a go.
Cheers. :D
duncmc
Re: Fuel Primer
Postby winterheating » Fri Jan 16, 2009 10:54 pm
duncmc wrote:Thanks for that Guy, I haven't looked too closely at the filter housing area yet. I just assumed it wouldn't have one judging by the discussions on here and from the TIS disc. It had a pollen filter by the way! :D
what do you mean by this?
winterheating
Re: Fuel Primer
Postby duncmc » Sat Jan 17, 2009 12:09 am
I was talking about stuff in my thread on My ex-RAC SWB 330 90ps.
Guy88 Post subject: Re: My ex-RAC SWB 330 90psPosted: Mon Jan 12, 2009 11:16 pm
So what do you recon the chances of the pollen filter having been changed are? I wouldn't put any money on!
If its got one then probably not
_________________
90 T330, SWB, RWD, Night heater, Booster Heater, Alloys, Electric Windows, Tailgate, remapped by vantuner
Official Ford Transit Forum Windscreen Banners Available PM me for details
http://www.facebook.com/group.php?gid=29188789670
duncmc
Re: Fuel Primer
Postby duncmc » Sat Jan 17, 2009 2:50 pm
:D :D
Yipeeeee. Got it going. Couldn't look at it until this afternoon, so left batteries on charge.
Loosened injectors and with a full fuel filter, then the crucial bit I think was to get the wife to crank over whilst I was under bonnet waiting for fuel to come out of injector pipes. Then did back up. It was nearly starting as I did last injector pipe back up. Then fired up and away it went. I'm happy now. :D
duncmc
