Seat Battery Access 2007 Transit
Postby simoncelox » Thu Feb 12, 2009 5:11 pm
RE the above can anyone tell me without requiring the dexterity of Houdini how to remove the metal bracket that retains the battery. The Ford handbook supplied bears no resembles to the actual set-up. There are 3 fixing points. One with an accessible bolt we have removed. The other two are each different and appear to require access to a bolt head from inside the seat frame the trouble is the battery is in situ and this makes it difficult. There also an internal lip that prevents access by a spanner - its all quite bizarre!
simoncelox
Re: Seat Battery Access 2007 Transit
Postby spospe » Thu Feb 12, 2009 11:28 pm
You need to remove the seat first by undoing 4 Torx bolts (they are T40 size). Then you need a 10mm socket or similar on a longish extension to undo the bolt that is facing the handbrake.
The above is based on my vehicle which is a 2007 350-140 rwd and has two batteries under the driver's seat.
spospe
Postby Jezclayton » Fri Feb 13, 2009 3:59 am
I have done this a few times and found it was much easier to remove the seat. You can do it with the seat slid fully forward but are likely to short the battery this way when lifting the bracket out.
Only takes 10 minutes to remove the seat so why stress yourself.
Current - Custom 290 L1H1 DCIV Limited 2.0 EU6 170ps 09/17
Previous - MK7 SWB 140 T280S Limited 2.2 FWD. 03/12 (Stolen)
Previous - MK7 MWB 130 T300 GLX 2.2 FWD. 04/07 (Sold)
Jezclayton
GLX Posse
Postby Transit bandit 67 » Sun Dec 03, 2017 5:22 pm
Yeah you have take the drivers seat out then very easy to do
Transit bandit 67
Postby GunnerBill » Thu Mar 22, 2018 1:47 pm
Top advice here to remove the seat. I spent about 20 minutes trying to get the batteries out with no success before finding this thread.
It's a little fiddly getting the cover for the seat belt off as you need a fine blade to prise out the retaining clips for the seat adjusters but that is about it.
Oh yes don't forget to reattach the seat belt before putting this cover back on...
GunnerBill
Postby Altransit » Fri Mar 23, 2018 12:10 am
I just removed the four 13mm nuts, holding the seat to the frame, and tipped the seat over onto the passenger seat. I never touched the seat belt :)
Postby Marauder » Fri Mar 23, 2018 9:26 am
I have replaced the Battery twice now on my 2008 2.2 ,Never had to remove my seat to undo the bolts that hold the bracket on. Where I did have problems was the removing of that plastic cover, Fixed that problem about 5 years ago ,Having finally removing it I then cut in in half, Now removal/refit is very easy lol. When I came to fit this latest Big Bosch Battery I had to cut and modify that metal bracket that goes across the top of the battery. So there you have it I like to make life easy.
Ford Transit 280 SWB,,Year 2008,,2.2,, If it can,t be fixed/repaired/ with a 4 pound lump hammer then it must be an electrical problem.
Marauder
Postby dumper » Fri Mar 23, 2018 9:43 am
I have a seat swivel on mine so have no choice but to remove it why struggle and cut the plastic lid for 5 mins work
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby alan.patterson » Sat Dec 04, 2021 9:18 pm
To do this properly and without removing the seat, you will need to:
1. Slide the seat back and remove the two torx t40 bolts at the front. You will need a t40 bit plus an adapter to fit a square drive socket set rachet. Don't bother trying with a screwdriver torx.
2. Remove the horizontal cover under the seat
3. Slide the seat forward and wind the seat back forward.
4. Using a socket set (recommend a 1/4" drive) use an 8mm socket to remove the bolt on the side of the bracket holding the batteries facing the door. Using the 8mm socket on a long extension, do the same on the other side of the bracket from inside the battery box. For the nut at the tear, use a 10mm socket on an extension piece, taking care not to drop the nut. The bracket is then free.
5. Do not try to wriggle out the bracket without disconnecting the negative battery terminal on the rear battery. My strong advice is to place some plastic or tape over the positive terminal before removing the bracket, otherwise there is a very high risk that the bracket will flash over the terminals.
6. I do not know whether the code for the radio is lost on disconnecting the front battery. I set up a power unit to feed 112v through a resistor connected to the cigarette lighter.
7. Finally, disconnect the positive lead of the back battery and lift it out. If the objective is to replace the front battery, that will need to slid towards the rear, the negative and positive connections disconnected and then removed.
alan.patterson
Postby knobby1 » Sun Dec 05, 2021 8:05 pm
alan.patterson wrote:To do this properly and without removing the seat, you will need to:
Thanks for the nice "How to"....however....the original thread was started over 12 1/2 years ago and the OP hasn't been back here since.
