When replacing the rear discs on a 56 plate rwd variant, how do I remove the abs ring in order to get the disc off the hub? Do you just smash it off and replace it? Or can you use heat to ease it off and back on (reluctant to do this as the oil seal is so close!) Thanks, Jon.
