Transit van weight
Transit van weight
Postby mellymel » Thu May 21, 2009 10:12 am
HI
Please can you tell me the total weight of a Transit van 8S T280 as it would be empty.
mellymel
Re: Transit van weight
Postby BigNeil » Thu May 21, 2009 10:21 am
it depends what else you have in it
like fuel weight ?
odds and ends weight
BigNeil
Postby mellymel » Thu May 21, 2009 10:55 am
The weight of the van as if you were to buy it new, just say it was empty but with fuel. would the weight exceed 1200
thanks
mellymel
Postby ake » Thu May 21, 2009 9:07 pm
Roughly, the max gross weight is 2800kg, the payload is roughly 1000kg so an empty van weighs roughly 1700-1800kg :)
2 x 67 Custom 270 Trend
3 x 66 Custom 270 Trend
1 x 65 Custom 290 Limited
7 x 12 Transit 260 Trend
1 x 60 Transit 350
Or is it something worse?
Postby Altransit » Thu May 21, 2009 9:56 pm
ake wrote: so an empty van weighs roughly 1700-1800kg :)
That would be about right, as I took mine on a weighbridge last week, and it weighed "empty" 1920kg. It does have 6 more seats than a van though :D
Postby Vee4 » Thu May 21, 2009 10:24 pm
If you are thinking of the current model, you can view the official Ford figures here, although the brochures are from April 2008 so they don't fully reflect current production:
http://www.ford.co.uk/Commercialvehicle ... ddownloads
'69 Mk1 V4 :) >> '76 Mk1 V4 :) >> '84 Mk2 OHC :wink: >> '97 Mk5 Banana :D >> '09 Mk7 TDCi 8)
The van in front is a Transit. It might be my Mk7 - follow the trail of rusty water: Diary of an Ordinary Van
Vee4
Postby steviegall » Tue May 26, 2009 11:05 pm
i have a question sort of related to this topic,
i was wondering since the vans weight is ~2000kg does that mean i can drive one with a standard N.I. driving licence, i.e. the section on the licence that says "passenger vehicles with up to 8 passengers and below 3500kg"
im renting a van to help with a move on monday and im starting to get a little worried
steviegall
Postby ake » Wed May 27, 2009 6:16 am
Yes a transit 260 has a max gross weight of 2600kg so you should be ok :)
1 x 60 Transit 350
Postby steviegall » Wed May 27, 2009 10:01 am
thanks a lot for the help
steviegall
