Transit 05 Plate Cigerette Lighter Not Working HELP please
Postby mightymont » Thu Jul 09, 2009 8:50 pm
i have a ford transit 05 plate van . i was using an air compresser via the cigerette socket when it shut off. i have looked at all the fuses they are fine. just wondered if there is a relay or something else thats blown. any help would be great as i need it to charge my Tom Tom. when i apply 12v to the lighter socket via a battery it works fine i cant figue it out Cheers guys.
mightymont
Re: Transit 05 Plate Cigerette Lighter Not Working HELP please
Postby ake » Thu Jul 09, 2009 8:58 pm
It probably is a fuse did you check both fuse boxes :?:
Postby mightymont » Fri Jul 10, 2009 6:31 am
i tried the fuses in both boxes. i just want to cry.i think it needs a professional
mightymont
Postby GBBiker » Fri Jul 10, 2009 8:38 am
Pop up to Transitmania if you don't get it resolved in the mean time. We'll sort it for you :mrgreen:
GBBiker
Wrong Again!
Postby BigNeil » Fri Jul 10, 2009 10:19 am
its probably the unit itself (the lighter part) try another part in they are about £6 or so easy fix even I managed to it !
:D
ps is the compressor working on another ciggy lighter socket as it could be the compressor !
BigNeil
Postby Chalky740 » Fri Jul 10, 2009 11:40 am
It could be the air compressor. How long were you running it? Some have auto shut-off to prevent them over heating. Should work again after about 15-20 minutes cool down time.
Chalky740
Postby mightymont » Sat Jul 11, 2009 7:16 am
its not the lighter socket that works fine when i put 12V via a battery. their must be something else thats stopping it working. HELP :(
mightymont
Postby Swanning_it » Sat Jul 11, 2009 7:59 am
If you are referring to a 2005 model, here is the fuse layout for under the passenger side dash compartment which holds the cigarette lighter fuse. Fuse 73, 20A (yellow). Only trouble I have is that the fuse box in my 2005 model is actually off a 2004 model :? which is altogether different. Try this layout, and if it helps, good. If not I'll try to find the 04 layout.
Ian
Swanning_it
Postby ake » Sat Jul 11, 2009 8:52 am
Did you actually remove and check every fuse :?:
Postby mightymont » Sat Jul 11, 2009 11:08 am
yes i have removed and checked every single fuse both in the glovebox and engine bay. its driving me mad. i have even disconnected the lighter socket and put a multimeter on the in coming cable there is no voltage with or with out the ignition on
mightymont
Postby ake » Sat Jul 11, 2009 11:09 am
Is everything else working on the van :?:
Postby mightymont » Sat Jul 11, 2009 11:12 am
yeah nothing else is wrong at all its so weird mate
mightymont
Postby GBBiker » Sat Jul 11, 2009 11:16 am
Have you checked the actual socket for voltage? If you have a supply to it, then there is no reason there won't be a reading across the terminals. Have you tried another accessory in the socket like a phone charger?
GBBiker
Wrong Again!
Postby mightymont » Sat Jul 11, 2009 11:47 am
the socket works fine i have tested it with a battery, but there is no power on the in coming cable
mightymont
Postby Zacseed » Fri Apr 21, 2017 11:59 am
It's fuse number 50 on the diagram posted above which is a 10A fuse
As I have just had the same problem and solved it with help of an electrician and his tester
Zacseed
