Fuel pump leak????
Fuel pump leak????
Postby rob1mitch » Fri Jul 17, 2009 5:20 pm
Put my 04 transit 85 260 in for mot and it's failed on "(possible) Fuel pump leaking"
What could this be?
Rumour has it this is going to be expensive...... what are the my options?
Is there a common fault on these?
Will it need a new pump or could it be an auxillary part that can be replaced?
Any advice appreciated
thanks
rob1mitch
Re: Fuel pump leak????
Postby Dan T » Fri Jul 17, 2009 5:44 pm
I wasn't aware that it was an MOT failure :?
It's common to leak from the FIP Metering Solenoid. Ford want £341+VAT for the part. I can sell them for £235, but you'd need to change it yourself.
Dan T
