Andyg wrote:Oh,
I forgot to ask how you checked the oil level
Kedishen wrote:I followed the guide in the manual.
Get engine to operating temperature. Apply the handbrake, press the footbrake, run through the shifter 3 times, and then let engine idle for a min.
I didn't however pause for a second after each. I did not see this in manual. Do you mean pause for a second after each movement of lever? Or after each complete selection of all gears?
Kedishen wrote:Also, what is the best way to refill the gearbox with oil. You mentioned earlier that I will lose some into the container.
Is there a level bung somewhere to fill it on the gear box? And where can I access it?
Please excuse my inexperience.
