by Kedishen » Fri Oct 09, 2009 11:19 pm
Hello
I have a 95 150L 2.5 Td campervan with 4 speed automatic transmission (blame the misses).
On the way back from devon last weekend, the gearbox was unable to change up to 4th gear. The 1st 3 gears were usable, but were not shifting properly at the usual revves.
The box usually shifts:
1-2 @ 15-20mph
2-3 @ 30-35pm
3-4 @ 45-55
depending on engine revves and position of accelerator pedal.
Since the problem my gears shift:
1-2 @ 15-20
2-3 @ 40
Can't go to 4.
There is also a smell of clutch burn, although not bad (at least not as bad as my mum's car after she burnt clutch out)
Anybody know of any common causes and solutions for this that I can combat the mechanic with next thursday? My internet research has turned up not alot and I can't afford an expensive rebuild if he suggests it. I will more likely buy a reconditioned gearbox if needed.
Thanks.
Regards
Scott
As a result of this, I cann't pull up a hill and I cannot keep my speed along flat roads without reving the balls.
Livin' in me van in Portugal.
'93 Mk4 TD 150L Hitop Custom Camper
100ps Epic blue spot
