new van speedo not working
Postby hazza » Wed Oct 14, 2009 1:39 pm
hi folk looking for a little advice i just recently got myself a ford transit :)
its aford transit v 1999 2.5 80swb
when i got the van none of the dials were workin the speedo,the temp gauge and the fuel gauge"
i messed around with some fuses and got the fuel gauge and the temp gauge working again but the speedometer is still not working
is there anything that i should look out for 1st before spending money on new parts
iv tryed looking for any broken wires under the bonnet nat the gear box but to be honest im not sure what im looking for ?
i have looked around your site at other posts but nothigng relivent to my problem
any advice would be very much apreciated
thanks in advance
haz
hazza
Re: new van speedo not working
Postby MrMPuk » Wed Oct 14, 2009 1:41 pm
Postby hazza » Wed Oct 14, 2009 1:49 pm
i added the model ect ?
hazza
Postby hazza » Thu Oct 15, 2009 10:43 am
anyone any advice?
hazza
Postby madmark_50484 » Thu Oct 15, 2009 11:51 am
check this thread theres some things there to try
Past
MK5 98 R reg Transit 190 LWB Semi hi Top
Mk5 98 S reg Transit 190 LWB High Cube
Present
Mk5 96 N Reg Transit Luton
Forum for bus enthusiasts and preservationists
www.busesuk.co.uk
madmark_50484
Postby hazza » Thu Oct 15, 2009 12:46 pm
i'v tryed everything on that topic none of it speaks about the speedo not workin
i checked all the fuses wires ect already
cant see anything wrong with them i also checked the back of the clock incase there was a split in the board for the clock s but none there
i bought the van with this fault none of the gauges worked at all the temp gauge fuel gauge and speedo after i checked the fuses and replaced 1 the temp gauge and the fuel gauge started to work again but no speedo ? :(
any more idea s?cheers
hazza
Postby madmark_50484 » Thu Oct 15, 2009 1:07 pm
ok that was just a suggestion it could be the module that sits on tne gearbox and converts the motion into electronic signals.
Past
Present
www.busesuk.co.uk
madmark_50484
Postby hazza » Thu Oct 15, 2009 2:16 pm
what does it look like ? so i know what to look out for i havent had anything like this problem before so im new to it what am i looking for? thanks again for the advice
hazza
Postby MrMPuk » Thu Oct 15, 2009 2:20 pm
Have a look at wiring from the speed sensor at back of gearbox (nr propshaft),think there are 3 wires coming out of it,trace them from gearbox looking for rubbing/damage.
Postby hazza » Thu Oct 15, 2009 2:26 pm
ok thanks for that ill get onto it just now will let you know how i get on thanks again
hazza
Postby djc151084 » Tue Nov 03, 2009 5:54 pm
hi just woundring did this problem get sorted after as i have similor problem
cheerz
The Van = Ford Transit 100 "V" Reg (2000) 2.5d SWB Low Roof
Location = Tonyrefail (Rhondda Valleys)
djc151084
Users browsing this forum: Google [Bot], Google Adsense [Bot], metalworker0
