MinorMatt wrote:the epics have a habit of reminding you when the timing belt needs doing (every 50K by the way)
Its easy to check the timing with an 18mm spanner/socket a 13mm drill bit and a 9.5mm (it might be a 6mm on the lucas??) bit.
Behind the fuel filter is the crank sensor, this needs to be removed the bolt needs to be undone (will either be a 10mm headed bolt or a torx headed jobby) and it will then pull out.
using the blunt end of the 13mm drill, place it in the hole and gently push. Using the 18mm socket/spanner turn the engine over until the drill bit goes in (it should go all the way through the flywheel... you should be able to push it in at least 2" more than where it started, if not you have the wrong hole in the flywheel.
then remove the rubber bung in the timing case cover, you should be able to push the 9.5mm drill bit right into the pump (you could have a look with a torch to see if the holes line up!)
