fault code p0200??
fault code p0200??
Postby oilyrag1424 » Sun Jan 10, 2010 3:03 pm
As above code p0200?
Transit 135bhp 2005 jumbo. Van runs for a few miles then glow light flashs and drops down on two cylinders. on checking the engine it is only running on number 1 and 4 ?? turn off and restarts and does the same again!!
Anyone??
oilyrag1424
Re: fault code p0200??
Postby angeleye » Sun Jan 10, 2010 3:10 pm
p0200 is injector circuit malfunction, how many miles it done
angeleye
Postby oilyrag1424 » Sun Jan 10, 2010 3:19 pm
102,000 miles.
oilyrag1424
Postby angeleye » Sun Jan 10, 2010 3:52 pm
could well be injectors, if they are the originals, who read the codes for you, was it with ids, i take it it wasnt, as it would of told you what the code means,....
angeleye
Postby oilyrag1424 » Sun Jan 10, 2010 4:00 pm
Code read by Brothers Snap-on code reader. i did know the code was for injector circuit malfunction but i did think it would of put up a code for the individual injectors? not injector circuit malfunction. Also to have two injectors suddenly to stop seemed odd!
oilyrag1424
Postby angeleye » Sun Jan 10, 2010 4:17 pm
there could still be codes to be read,..do a search for leak off test,that will tell you a bit about injectors.... could be best to have injectors cleaned and tested approx £25ea at diesel specilist, to rule them out...at 100,000 there about past there best,, new injectors £200+ea at ford, bit cheaper at delphi specilist, maybe have them refur by them.ive got same van and had 4 sets 190,000. they are very tempremental....if you take them out remember which cylinder they come from as they are coded to the cylinders they come from(just in case you didnt no).bar doin the leak of test, hang on a little while befor you spend any money see if one of the transit techs comes up with anything.
angeleye
Postby oilyrag1424 » Mon Jan 11, 2010 5:49 pm
Injectors all checked and ok....now in the process of having the wiring checked...if not have been told poss ECU...But has been running fine today aprox 40 miles and all OK.
oilyrag1424
Postby angeleye » Mon Jan 11, 2010 6:13 pm
could be ecu but unlikely there pretty good, could of just been them injectors wanted cleaning, as they have to clean them to check them
angeleye
Postby oilyrag1424 » Mon Jan 11, 2010 9:34 pm
Have cleaned a earth lead up by the ECU on the bulk head and all seems OK at the mo,will see how it goes tomorrow.(fingers crossed).
oilyrag1424
Postby spanner-86 » Tue Jan 12, 2010 12:45 am
p0200 is grouped injector fault, possible it is the injectors but check all your wiring and connections thourouly 9/10 times its an earth fault to the injectors as they share the same wire. pull your harness back if need be you will eventually see a bad wire (corroded) or chaffed if i remember right check where th loom goes over the vac pump area. hope this helps :D
spanner-86
Postby oilyrag1424 » Mon Jan 25, 2010 8:10 pm
Well, all was well for about two weeks with no problems, Injectors where checked and ok, Wiring loom was checked and all ok, but the problem came back this evening ie not running on number 2 and 3 cylinder??. As said before i think they use a comman earth, is it possable to run new earth wires from 2 and 3 injector to the body or do they have to earth in the ECU??
Cheers
oilyrag1424
Postby oilyrag1424 » Mon Jan 25, 2010 9:34 pm
Right just checked the voltage coming down the wires to the injectors, no1 5.1 volts on each wire no2 1.6 volts on each wire no3 same as 2 and 4 same as 1 SO Iam now thinking it is the ECU??
oilyrag1424
Postby oilyrag1424 » Wed Mar 17, 2010 9:35 pm
Only just got the van back!! Not ECU or wiring but a dead short on number 3 injector which was telling ECU to shut down this injector but the ECU also shut down number 2injector as they share a common live...
Any way van runs perfect...
oilyrag1424
Postby kevin47 » Sat Mar 20, 2010 9:05 pm
Hi, I have the same van & i,m interested in want scannners work on these transits, could you give me the system they use.
And want lead adapter I need. Any info would be most appreciated.
kevin
kevin47
