by hiram23 » Sat Nov 29, 2014 12:14 pm
Posted the other day about a brake problem on 2003 ford transit. The brake pedal went hard on braking like a brick under the pedal, narrowly avoided an accident. after stopping the brakes returned to normal. the garage couldn't find a fault, checked the lot and road tested. The garage replaced the front discs pads and, master cylinder, as this was the consensus from several mechanics. This lasted two days and without warning it happened again, coming to a roundabout, luck was on my side and anybody else as well! Managed to stop called the Mot garage and they came out , by the time they arrived started up tested the van the brakes returned to normal. Have now replaced the vac pump and the servo.
It appears but this is third party from the Ford dealers that they are aware of this problem. It is the servo piston and main spring jamming, in the unit.
My mileage is 118000 so not excessive. Don't anyone ignore this problem its dangerous. hope this helps. Will post this elsewhere.
