I'm at this stage only contemplating to do a conversion from (not so) smartshift to manual but would like to hear from other (more experienced) members before deciding.
I have an MK6 2004 Transit 2.4 TD with smartshift.
Obviously I'd have to get the gearbox and clutch but what else would be required partswise?
Is it a simple reprogram of the ECU or would I need an ECU of an manual van aswell?
Same driveshaft or shorter/ longer?
I've already contacted a company here that does them but they charge about the same as what the van is worth (around $10.000AU) and that's beyond my budget.
Like I said I'm only contemplating it at this stage but any advice appreciated.
Also would the newer 6 speed manual box out of a MK7 fit or are they way different?
cheers fumbduck
