Luke J wrote:Has anyone got a full pinout for this module? I am fitting my alarm and have the doors locking and locking. I can't get it to double lock, touching lock wire too ground twice doesn't work. I would like to use the door switch signals if possible to make wiring a bit easier going.
BTW pin 10, rear unlock, the wire was cut already, is it best to keep that way?
Hi I can tell you rest of pinout if you look at the plug pictures above. The double lock feature requires two separate pulses one after the other on two separate wires, the 'lock' and the 'set' inputs, likewise to unlock is 'unlock' and 'reset' wires. Leave the rear door unlock wire cut, as that is the safety / security mod done by fords, it stops all the doors unlocking if the rear door harness is cut through from outside.
Ok pinout is as follows.
Green Plug:
1. Indicator feed right hand
2. 12v permanent feed
3. Rear/Side/Drivers/Passengers door motor feed
4. Rear/Side door motor feed
5. 12V permanent feed
6. -ve to chassis
7. Rear/Side/Drivers/Passengers door motor feed
8. Drivers/Passengers door motor feed
9. Indicator feed left had
10. 'Set' input rear door lock mechanism
11. DLC k-line (diagnostic socket connection)
12. (Spare / not used)
13. Radio ground connection (alarm trigger on radio removal)
14. Bonnet switch ground input (alarm trigger [if used])
15. (spare / not used)
16. Horn / alarm siren feed (if used)
Blue plug:
1. 'reset' input from rear door mechanism
2. Rear door ajar input (interior light trigger) negative with door shut, open circuit with door open
3. (spare)
4. 'reset' input from drivers or passengers door lock mechanisms
5. Sliding door ajar input (left side) interior light trigger pinswitch type so negative with door Open, open circuit door closed.
6. Sliding door ajar input (right side) interior light trigger pinswitch type so negative with door Open, open circuit door closed. (European models only)
7. 12v Ignition switched feed
8. Ground output to operate interior light relay
9. Aerial lead (for remote fob)
10. 'unlock' signal from rear door mechanism
11. Passenger door ajar input (interior light trigger) negative with door shut, open circuit with door open
12. 'set' input drivers / passengers door lock mechanisms
13. 'lock' input rear door lock mechanism
14. 'unlock' input drivers / passengers door lock mechanisms
15. 'lock' input drivers / passengers door lock mechanisms
16. drivers door ajar input (interior light trigger) negative with door shut, open circuit with door open
Andy
