dodgy01 wrote:just be a bit aware of what you put up here
i dont know if you are aware but using veg oil with out paying tax to the government is tax evasion
(quite serous)
you never know who are watching
dodgy01 wrote:oh right sorry i was mis led
Note: If you have produced less than 2,500 litres in the last 12 months, or if you expect to produce less than this amount in the next 12 months, you may be an exempt producer. If you are an exempt producer you are only required to keep production records (see item 2 in the above table). See paragraph 4.2.1 for more information.
MrMPuk wrote:There's lots of info about it on here but all I can say is vegetable oil is for frying chips not running engines.
phil290 wrote:The mk6 needs to be modified to run any veg oil at any percentage. As it being a direct injection engine the fuel is ignited over the top of the piston crown. Being a thicker viscosity the fuel doesnt get fuly combusted untill the engine is warm so the sooty residue makes like a carbon build up that sticks the rings to the piston. 'ring gumming'. You will need to run a twin tank conversion to run veg oil in a mk6.
