Number Plate Lights
Number Plate Lights
Postby Dave The Barge » Mon Nov 29, 2010 6:49 pm
Hi,
My number plate lights are not working on my 05 tranny.
Bulbs o.k.
Fuse o.k.
No power to bulb holders ( did get a reading of 0.6 volts)
Any ideas ???
Dave.[/b]
Dave The Barge
Re: Number Plate Lights
Postby dodgy01 » Mon Nov 29, 2010 6:51 pm
if your desperate run a wire from the side lights till u get time to sort it
probibally the cable as it goes through the door
dodgy01
Postby Dave The Barge » Mon Nov 29, 2010 6:57 pm
Thanks,I might have to give that a try.
Do you know how the power gets to the rear doors?
Dave The Barge
Postby dodgy01 » Mon Nov 29, 2010 6:59 pm
look at the side where the hinges are there will be a black boot type thing and the wires will run through there
dodgy01
Postby Dave The Barge » Mon Nov 29, 2010 7:05 pm
cheers, i'll have a quick look in a minute.
Dave The Barge
Postby dodgy01 » Mon Nov 29, 2010 7:19 pm
ok mate shout back if your stuck
dodgy01
Postby Dave The Barge » Mon Nov 29, 2010 7:28 pm
Hi Dodgy,
Just had a quick look but can't see anything like a boot!
There's the two hinges either side and something that I think carries cables to stop the doors opening up too far.
Dave The Barge
Postby jay » Mon Nov 29, 2010 11:19 pm
the black thick thing that looks like a thick cable is the wiring loom..you will find its proberbly the wire has snapped inside or has come off the plug by the rear light....remove the rear light and you can see the loom from the door and where it connects to the vans loom there is a multi plug see if you got power there as well..failing all that thread a new wire from rear light to number plate lights..
100ps mk6 in moondust silver with mk7 front end
jay
Postby Terry » Mon Nov 29, 2010 11:40 pm
Dave
Where are you checking for power ? , I guess at the bulb holder ? They are shit I have replaced mine with ones from a trailer shop £3.00 apiece & I put LED's in so no more problems.
H.T.H.
Terry
Pallet Puller
Terry
Postby Dave The Barge » Tue Nov 30, 2010 11:08 pm
Thanks Everyone, you've all been a great help.
I won't get a chance to have a proper look 'till Friday, but when I do I'll report back on my progress.
I was wondering if the fault might be 'connected' to the trailer wiring ?? I really hope not 'cos then I'm totally knackered !!
Dave The Barge
Postby Dave The Barge » Fri Dec 03, 2010 1:50 am
Hi,
I had a look today and yeah Jay you were right, the black plastic thing that runs from the rear light cluster to the rear door does carry the cables to the number plate lights.
The orange/blue cable has a nick in it.
The black cable has been completely severed in two places.
I shall try to rewire both cables from the plug behind the light cluster to the number plate wiring tomorrow.
It was minus 5 out there today, (real brass monkey stuff) so wish me luck.
Will report back as soon as possible.
Cheers everyone.
Dave The Barge
Postby Dave The Barge » Tue Dec 07, 2010 1:27 am
That's it, job done, the number plate lights are working again.
Rewired from the plug to the number plate lights. Everything working o.k. again now.
Cheers everyone, you've been a great help.
'till next time,
Dave.
Dave The Barge
