ford connect cutting out while driving
Postby boborrob » Mon Dec 06, 2010 1:19 pm
hello,i have a connect tdci 2004 reg, the glow plug light comes on and flashes,then the engine loses power and cuts out,
this has happened several times now,does anyone have an idea what the problem is,thanks
boborrob
Re: ford connect cutting out while driving
Postby Kent Discos » Tue Dec 07, 2010 1:08 am
use the search tool at the top :wink:
search flashing glow plug etc... should give you a lot of results
Jack Wilson | 2017 Transit Custom 290 130PS from Absolute Vans
Kent Discos - http://www.kentdiscos.me.uk
Kent Discos
Postby Altransit » Tue Dec 07, 2010 1:14 am
You really need to get the codes read to find out why the fault light is flashing :|
Postby willodling » Tue Dec 07, 2010 4:44 pm
mine has just done this too, did it a few times then started it back up again and it seems fine now?
willodling
Postby boborrob » Mon Dec 13, 2010 7:11 pm
Thanks for the previous replies to my post,i had the fault code read it's a p0251 which apparently is the pump and/or the injectors,
the advice i've had is to check fuel filter for metal if clear good news :) if not then the pumps done for :( would this info be right?
also to have injectors pressure tested would be £15 a pop,and then £95 per recon if needed,does this sound about right?
boborrob
Postby Altransit » Mon Dec 13, 2010 7:58 pm
It is a pump problem, but I think it's repairable :|
P0251 Injection Pump Fuel Metering Control A Malfunction
Postby boborrob » Mon Dec 13, 2010 8:21 pm
hope you're right!
boborrob
Postby mlevit » Sat Jan 01, 2011 9:39 pm
[quote=
Code: Select all
[code][code][list=][list=][list=][/list][/list][/list][/code][/code]
"boborrob"]hello,i have a connect tdci 2004 reg, the glow plug light comes on and flashes,then the engine loses power and cuts out,
this has happened several times now,does anyone have an idea what the problem is,thanks[/quote]
boborrob wrote:hello,i have a connect tdci 2004 reg, the glow plug light comes on and flashes,then the engine loses power and cuts out,
mlevit
Postby leekell » Fri Mar 04, 2011 8:20 pm
same problem bob i have a 04 reg exactly the same as yours,have had injectors checked ,replaced one of them,fuel sensor changed and new accelertor changed,had pump checked but still does it,mechanic thinks it maybe a wiring problem,also have been told its a ford problem but they didnt want to call them back in,not sure how true this but looking online at different forums it seems a bit suspect as theres a lot of owners with our problem????????????????
leekell
Postby me&myvan » Fri Mar 04, 2011 8:30 pm
Change the fuel filter.
I've had this on my van and 2 focus's
I was told the fuel delivery pressure was affected by a blocked filter and it gave pump, injector fault codes.
Cured mine never had problem since.
Filter £20, worth trying first. Takes 10 mins to change
Only trying to help, i'm not an expert.
Dave
me&myvan
Postby boborrob » Sat Mar 05, 2011 11:52 am
I changed the filter a few weeks ago,made no difference,it'll drive all day long at low speed low revs but as soon as it's under load on acceleration
it cuts out,doesn't go into limp mode,just cuts out.It's probably the pump but can't afford to have anything done at the minute, times are hard :(
boborrob
Postby simes » Sat Mar 05, 2011 5:35 pm
throttle pedals are a very common fault on connects, if you know someone else with a connect try swapping theirs and see what happens, only takes a few minutes to change
simes
Postby phil_m » Sun Mar 06, 2011 11:53 pm
My van done this last week for the first time, changed fuel filter this weekend so I am hoping this will sort it.
phil_m
