Immobiliser wont turn off
Postby plroofing » Sat Oct 29, 2011 3:20 pm
Hi guys,
the problem I have is the immobiliser wont turn off when I put the key in my transit.The dash board light never stops flashing, and if I turn the key it then starts flashing much faster. If I put the key a 100 times and I'm lucky it might go off once and the van starts.
So my question is this. Could it be the transponder ring around the ignition switch thats at fault or the chip in the key itself. I would have thought that if it was the key it would never work, but like I say every now and then it starts if the immobiliser light goes off. Or is it something else completely. I have had a fault code of B2139 Data Mismatch received. Data does not match, error.
Its a 2002 T280 Transit.
Thanks for any help.
plroofing
Re: Immobiliser wont turn off
Postby winterheating » Sat Oct 29, 2011 3:23 pm
Do you have any other keys next to it?
winterheating
Postby plroofing » Sat Oct 29, 2011 3:51 pm
Not sure what you mean by that. Theres only one ignition key, and its on its own ring
plroofing
Postby winterheating » Sat Oct 29, 2011 3:53 pm
How many and what keys are on your key ring?
winterheating
Postby plroofing » Sat Oct 29, 2011 3:55 pm
The only other keys are my house keys.
plroofing
Postby Guy88 » Sun Oct 30, 2011 12:18 pm
leave the key turned on for a minuit and it will flash a fault code via the LED
will come in the form of 2 sets of flashes e.g flash..flash..pause..flash..flash..flash.. repeated
that would be code 23
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby plroofing » Mon Oct 31, 2011 12:48 am
Guy88 wrote:leave the key turned on for a minuit and it will flash a fault code via the LED
Hi Guy,
Ok tried that and this is what happens.
Key out.... steady flashing led
Key in ......steady flashing led no change in speed from key out of ignition
Key in turned once ...steady flashing led no change in speed from above
Key in and turned twice so ignition lights on .... Led flashes very fast continually no pauses.
Its as if the van doesn't even know the key is there until I turn it twice.
plroofing
Postby Altransit » Mon Oct 31, 2011 1:08 am
plroofing wrote: Key in and turned twice so ignition lights on .... Led flashes very fast continually no pauses.
When it's flashed like this for about a minute, watch for the two digit flash code :wink:
Postby plroofing » Mon Oct 31, 2011 10:33 am
OK done the above, and after quite some time watching the disco lights I got the flash code :D it was 23.
So what does this mean and what's the cure?
Thanks for the help!
plroofing
Postby Altransit » Mon Oct 31, 2011 11:13 am
Code 23 is a key/immobilser mismatch, the code is not being recognised between the key and the immobilser module
Postby winterheating » Mon Oct 31, 2011 11:15 am
What happens if you just start it quickly with the key?
winterheating
Postby plroofing » Mon Oct 31, 2011 11:55 am
Altransit wrote:Code 23 is a key/immobilser mismatch, the code is not being recognised between the key and the immobilser module
So whats more likely to be the problem. The key has lost its code or the transponder ring round the ignition switch is stuffed.
plroofing
Postby winterheating » Mon Oct 31, 2011 11:59 am
The key transponder.
My old one was always iffy, but started and just flashed afterwards, every other time.
One day it just stopped working... New transponder and know more problems.
Try turning it quick and holding it at full ignition till it cranks, may have a second pause, then crank.......
winterheating
Postby Altransit » Mon Oct 31, 2011 12:00 pm
If it's intermittent, I would suspect the transponder or the wiring :?
My Focus does something similar to this if you put in the wrong key and then put in the correct key, it won't then recognise the correct key :shock: :?
Postby plroofing » Mon Oct 31, 2011 12:03 pm
OK thanks guys, gonna go to rip you off Fords and get a new transponder ring and see what happens
plroofing
