mk7 engine managment light how to turn it off
Postby flinty06 » Sat Nov 12, 2011 7:11 pm
hi folks ive got a 2006 m7 transit 85 300 and the engine management light has came on how can i turn it off?ive hav a focus an my exhaust trips my mil light evrey now and again so i pull a fuse out for 10 mins and that sorts it out is there any thing like that on the transit?
2010 swb 115 trend panther black
2014 vw caddy c20 102 trendline blackberry
flinty06
Re: mk7 engine managment light how to turn it off
Postby angeleye » Sat Nov 12, 2011 7:26 pm
have you thought why its came on :!: have your codes read see if there is a problem
angeleye
Postby flinty06 » Sat Nov 12, 2011 7:35 pm
the light came on last week but went out so i got the codes read and ford couldnt find anything wrong no faults!then driving home to night it came on again jus thot there might have bin a easy way of turning it off without costing me £35 for ford ta say there nothing wrong
flinty06
Postby angeleye » Sat Nov 12, 2011 7:45 pm
turning ignition off ,normaly would turn light off,is there no problems whats so ever ,no slight miss fires :?:
some times you do get a glitch,and light will come on,check all connections to sensors,etc,check connections to foot pedals also,
take note if it happens again when it came on etc ,
angeleye
Postby flinty06 » Sat Nov 12, 2011 7:54 pm
thanks for that il have a look at it tomoro i cant say ive noticed if it was running ruff the only thing ive noticed is the fan has bin a bit more than normal :?:
flinty06
Postby ake » Sun Nov 13, 2011 8:33 pm
Try and take it to get codes read whilst light is on :wink:
2 x 18 Custom 270 Trend
2 x 67 Custom 270 Trend
3 x 66 Custom 270 Trend
1 x 65 Custom 290 Limited
7 x 12 Transit 260 Trend
1 x 60 Transit 350
Or is it something worse?
Postby flinty06 » Mon Nov 14, 2011 11:39 pm
thanks for all the tips and advice folks i went to the van this morn and the light was off so its booked in to another garage for thur just to see if they can pick up on anything the van drives spot on i cant see anything wrong with it only thing i can see is when i turn it off it makes a clicking noise just after the engine stops could any 1 shed some light on the clicking noise?
flinty06
Postby AndyG » Mon Nov 14, 2011 11:51 pm
It's supposed to give a "scratching it's self" noise for a couple of seconds after switch off :!:
It will be the self cleaning action of the EGR valve :wink:
Postby flinty06 » Mon Nov 14, 2011 11:55 pm
that makes sense now you say it!you have to love this site its so help full and the people on it are so helpfull :D
flinty06
