Wooden Bulkhead for Transit Connect SWB
Advertise any transit parts you have here free to other members!!
Postby millertime_1985 » Wed Sep 03, 2014 9:24 am
I have a wooden Bulkhead for sale.
I bought the bulkhead about 2 and a half years ago , its solid wood and has been covered with some material (before I bought it)
it appears to have holes drilled so you can secure it to your TC pillars (behind the cabin doors) but I cant be sure as I never properly fitted it, I only ever secured it using a couple of cable ties.
There is a hole drilled in the middle lower edge (just behind the handbrake console area) that I believe was used by the previous owner to heat the rear section of the van with some sort of heater. it is pretty solid, and has the added benefit of having a sliding "hatch"
I want to add that the material on the corners has started to come away from the wood, but should be easy enough to sort with a bit of super glue
Only getting rid of it as I bought an Original Ford Metal Bulkhead last summer, and now I need the space in the garage.
ideally you would need to collect it as its too big for a courier to handle (especially as its a single piece and doesn't break down), however if you are local-ish to the Motherwell/Glasgow area I may be able to deliver it for a small "donation".
Serious enquiries only
Its Not a Van..... Its a Transit
millertime_1985
Re: Wooden Bulkhead for Transit Connect SWB
Postby Cal1990 » Fri Dec 19, 2014 6:15 pm
Much to deliver this to Edinburgh mate ? Or could meet in middle somewhere
mk7 Transit swb low roof in beautiful black :)
Cal1990
Postby barmiebrumie » Mon Dec 22, 2014 2:41 pm
Guess Birmingham is to far :( :( :(
barmiebrumie
Postby millertime_1985 » Wed Dec 31, 2014 10:35 pm
sorry all, it's long since gone... too many time wasters
millertime_1985
Return to Free to good home!!
