ok, well the bumpers gone now....
Does anybody need anything off the engine? Those engine mounts look different to my MK5 ones.
I took the mudguards off, not in the best of shape as the steel has started to rust inside them and started to swell up, ect.
Ford Part Numbers.
DRIVERS:
86 VB 16 A 562AA. G18013.
PASSENGERS:
86 VB 16 A 563AA. G18013.
They don't even look close to fitting my MK5...... But then again I rebuilt that whole inner wheel arch area out of beaten sheet steel... I'd be very surprised if MK5 ones even fitted...
But this is a funny thing.... when I took the mudguards off the MK3 there was no real rustproofing behind them... no under-sealant, stone-chipping or anything. just painted steel.... the rest of the inner wheel arch was fine.... just not behind the mudguard.
Perhaps the mudguards get put on after the paint is dry but not before the under-seal is dry and the mudguard pushes all the under-seal out of the way.
Anyway, the mudguards are here if someone wants them.
Cheers...
