Mk 5 Rear door bits & Side door ply liner
Advertise any transit parts you have here free to other members!!
Postby evilgoat » Mon Aug 08, 2011 1:47 pm
I have just stripped a Mk5 drivers side rear door for prep so I can repleace the peice of rust that is my current one before the window falls out.
As a result I have hinges, the lock unit, a high security barrel (no key) and all the gubbins from inside the door bar the outside door handle. If anyone wants it they are welcome to it all, bolts the lot. The guides are there as is the rubber seal but the rubber isnt in a good way.
Also as I now have a window in my side door I have the ply liner from my side door. Needs a sand and paint but there is nothing wrong with it, also free to a good home.
evilgoat
Return to Free to good home!!
