Started on o/s inner sill tonight at the rear, using 2 mm plate, surely it will last and its easier to weld to than 1mm, I tied it into the front spring hanger I welded up last week. Had to cut quite alot out to get to clean metal and the higher you go up the sill it ain't flush so alot of hammering to get metal touching so it can be welded, not easy welding etc lying on your back
