Loots Red custom
Re: Loots Red custom
Postby loot » Fri Apr 21, 2017 1:33 pm
Blew it out, those start covers are bad for dog hair, they are thick material that doesn't look porous but by god 110psi and it still takes ages to get the hairs out :?
Also removed the door panel for my little mirror modification but I'm having a coffee and looking at diagrams I'll go back out in a bit, wish me luck in that i don't fook the modules up :P
(Non serviceable relay?) Who you talking to? :mrgreen:
07 350 170ps
Ids map here
https://uk.virginmoneygiving.com/fundra ... Id=914018#
loot
Postby bigjohnthomas » Fri Apr 21, 2017 2:27 pm
Have you done that mirror thing yet ?
Gets everywhere dog hair
Miss allcock gets it in her bra :?
I'll have to try the air line thing on her :P
Bum holes
bigjohnthomas
Postby loot » Fri Apr 21, 2017 3:29 pm
bigjohnthomas wrote:Have you done that mirror thing yet ?
Not yet, soon as i had that coffee i went into weekend mode :(
I never use a vac, always airline as it only takes a few mins, i used to spend upto 4h vacuuming and cleaning up my escort :? Life's for living damn it. :P
07 350 170ps
Ids map here
loot
Postby loot » Fri Apr 21, 2017 6:42 pm
07 350 170ps
Ids map here
loot
Postby loot » Fri Apr 21, 2017 7:36 pm
Dunno what all the fuss is about :roll:
1 little relay, 1 wire cut, bobs your aunty. :P
https://youtu.be/RjUO9r5QXwU
https://youtu.be/NeBz9Sh-HZ8
Needs fine tuning tho, unlock is too fast first time so it flinches and you have to press unlock again, nothing happens on single lock (as me and allcocks engineering wanted) then double lock does it, presently it is dumb so can keep doing it on multiple presses and can be opposite so i expect it'll get quite annoying at some point until modification of some kind can be made :D
Well what do you want for nought like?
07 350 170ps
Ids map here
loot
Postby karl » Fri Apr 21, 2017 8:34 pm
loot wrote:Dunno what all the fuss is about :roll:
Whos a clever boy then :mrgreen:
I do actually say thing like this to meself :lol:
karl
Tranny Lover!!!
Postby loot » Fri Apr 21, 2017 8:44 pm
:lol:
Also found the auto windows module i bought for the mk7 so i might see if i can install that too and latch the power to the windows with the key out. :mrgreen:
We'll see.
07 350 170ps
Ids map here
loot
Postby bigjohnthomas » Fri Apr 21, 2017 9:00 pm
Splendid :P magnificent work there loot
Beer . whisky, champagne drink from furry goblet
I shall be procuring a relay with great haste :P
I fancy one with a couple of second timer on it 8)
So its the blue wire and the yellow one then?
Switch in so you can disable it n all dat ?
:D
Bum holes
bigjohnthomas
Postby loot » Fri Apr 21, 2017 9:22 pm
Relay output (ground either side) to the mirror connector pin 4 and pin 8(just a bridge)
Then at the actuator connector (it's numbered 1-8) you want pin 3(this is listed as ajar in the ford diagrams and you'd want pin 6 but you don't as i found out that ford diagram ppl are morons and thick as fook bloody waste of 13 pounds bloody Ford)
So just cut pin 3 wire about 15mm from the connector or more and then join each end to the other legs of the repay coil, how it works is both locks are ground at rest then you unlock it and the bcm internal relay output goes live so the relay coil is energised let's say pos to neg, then you press double lock and the relay coil is energised neg to pos, it works because the coil is just am electromagnet.
Wow loot you blow my mind 8)
Remove the door panel and the connector is far right just behind the sound proof and just unclips dead easy :P
The wires are all black so just use the pin info i said.
I want to make it so that if i press unlock then it opens the mirrors but then nothing if i repeat, then the same for double lock. Needs to be a bit professional eh :o
There may be a circuit we can use in stead of the relay but the trouble with circuits is you need to know what the circuit is/does in order to get 1 :roll:
More testing for now tho.
07 350 170ps
Ids map here
loot
Postby ned » Fri Apr 21, 2017 11:51 pm
Aren't you a clever boy with your mirrors (ford warranty now void :lol: )
So Dr Tesla is it possible to make the electric windows auto close when locked with the key fob :?: N
03 transit 125t280 2.0 tdci swb executive college blue 92 crewcab. Built in Belgium so deserves lots of love. 212,000 miles on the clock.
Instructions for use. fill with fuel. start engine. drive like a t#@t.
ned
Postby loot » Sat Apr 22, 2017 9:30 am
What fookin warranty? Sis they did it? I did :mrgreen:
Auto roll up has been avaiable for a long time, sir limitedblack fitted auto up/down I his airport taxi i believe 8)
It works on similar principle there's 2 relays which throw when activated but never have either window powered in a way that will short out.
http://m.ebay.co.uk/sch/i.html?_nkw=Aut ... up+windows
07 350 170ps
Ids map here
loot
Postby RustWidow » Sat Apr 22, 2017 9:32 am
Nice job loot, I want that! Lol
RustWidow
Postby loot » Sat Apr 22, 2017 9:36 am
Roll up windows?
:P
07 350 170ps
Ids map here
loot
Postby PheoBlue » Sat Apr 22, 2017 9:57 am
loot wrote:Used a hair dryer in the 240v outlet with the engine running to heat up the hilti vinyl on the roof and remove it :mrgreen: makes a hell of a difference with it hot, cold and it just shatters, got and it came off in large pieces, had to partially lie with 1 leg along the roof and the other on the Hilti chair in the side. Lucky i had the pram rails to hold.
Bit annoyed because the rear rubber bung has had a sharp blade around it to install the vinyl and there is brown there which I'm going to lacquer over once i clean it.
Found some turtle wax compound in the garage new in the tub, might have a little look see :D
My invertor is only 1000w so no abuse it cuts off :(
At least you only had the roof I got the whole thing, and it's not responding very well to the heat , still breaks off in tiny little pieces. Image
Sent from my SM-G930F using Tapatalk
PheoBlue
Postby ned » Sat Apr 22, 2017 11:14 am
Going to have to get myself a couple of them, hope its easy to do as am a bit dumb when it comes to electrics, I'll probably end up with the wipers activating instead of the windows closing :lol: N
ned
