Loots mk7 keeper
Re: Loots mk7 forskin
Postby loot » Wed Apr 17, 2024 8:39 am
Wtf :shock:
New apec disks, bolt to flange holes different,call ford there's 10mm and 12mm available. Ok so bigger is stronger. But the flange holes are different too . Can't see any of the bigger type either :cry:
07 350 170ps
Ids map here
loot
Postby loot » Wed Apr 17, 2024 8:40 am
@andz327
07 350 170ps
Ids map here
loot
Postby ned » Wed Apr 17, 2024 5:45 pm
When this is finished we’ll have to meet up so forskin can meet fanny :lol: :lol: :lol: :lol:
Are you not replacing the rear arch now you have the repair panel
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby loot » Tue Apr 23, 2024 3:17 pm
ned wrote:When this is finished we’ll have to meet up so forskin can meet fanny :lol: :lol: :lol: :lol:
Nah, arch is fine just surface rust. I don't want to cut into larger panels see. Also I plan to fit the plastic arches so it'll cover it all so a bit of pointless extra work if I'm honest. Been messing about with the disk for a could day's now, didn't need that. :lol:
Thinking of removing the engine to service it and get into the firewall area to paint it all.
07 350 170ps
Ids map here
loot
Re: Loots mk7 keeper
Postby loot » Tue Apr 23, 2024 3:19 pm
Passenger side is getting there, I can see the end of the tunnel.
The drivers side needs inner arch front and rear etc but there's only 2 holes in the inner cill it is much bigger panel than the step side, i don't know whether to botch it up for the mot or to convert it to the sliding door then mot it.
07 350 170ps
Ids map here
loot
Postby loot » Tue Apr 23, 2024 3:22 pm
Weldering :P
07 350 170ps
Ids map here
loot
Postby loot » Tue Apr 23, 2024 3:40 pm
07 350 170ps
Ids map here
loot
Postby TiviamTonal » Tue Apr 30, 2024 11:27 am
Sounds like a solid project van! Here's a short and to-the-point reply:
Nice find! Looks like a well-equipped 2006 Ford Transit MK7 with good service history.
Highlights: 2.4L engine, SWB, GLX model with conveniences, 98k miles with recent work (brakes, turbo, service).
Project started: Interior/roof cubby voojio removal, rust check underway.
What are your plans for the build?
TiviamTonal
