deankdx wrote:i keep forgetting how little room there is in the V4 engine bay, Dad had a Leyland V8 in his, most was in the cab.
what bits are you running air con wise? the XF falcon compressor is usually crap(just noted you have an XF condensor), i have a couple of utes and had heaps of them in wrecks all dead too.
i am probably fitting a Sandon one to my van, and an under dash knee freeze where the glove box lived but i plan to make ducting off it up to centre dash vents. i was considering making a fibreglass or steel box for a late model ford evaporator and custom duct that but getting a fan in it was looking like too much mucking about.
As I said to Toni..this is the 'radiator bay'...the engine bay is in the cab.It's kind of ironic that this is a full firewall cut,recessed engine project but because of the transit's size it's not particularly radical...I've done a 350 chev into a LJ and it was simpler but far more interesting when it comes to power to weight ratio.
We bought an XF as a fill in car for the project period...so it seemed fortuitous to rob it's aircon...which I will add didn't work...I figured we'd fit it all in with no additional cost and later fix it's problem....ie regassing/compressor seals....or it seems from what you said..a new compressor...If it comes to that..I'll keep the name Sandon in mind and look into other brand units as well (thanks for the tip).
Speedy airspares make a 12v heat and cool concealed unit...It's just over $200, goes under dash and has 4 outlets that have no controls to shut them off...Some outlets will be shut off by eyeball vents ie dash....but we came up with a doozy of a thing that with a single cable control will alternate between 1. demisters off/fresh air to dash off 2.Fresh air to dash on 3.Fresh air off/a.c or heater to demist on..it's a strange rotary drum control that redirects ducting and will probably be made from ABS plastic. There is an under dash unit that has inbuilt controls but it's about $900. The unit we are getting comes with 2 rotary controls (fan switch & thermostat switch) we will be retrofitting these into the heater control housing from a 1953 Dodge (a gigantic/spectacular tribute monument to chrome)..and of course use the chrome Dodge knobs on the new switches.
The idea of flogging an evaporator out of an existing unit is interesting....Figuring out those D.I.Y time to money ratio equations can be difficult sometimes ...and I know what you mean about too much mucking about..sometimes I'm not smart enough to realise it...until I'm well into the 'muck'
