My 2.5 TDi project
Re: My 2.5 TDi project
Postby ColinJack » Sun Feb 03, 2013 8:58 pm
Cool copper link pipes on those yellow spots. Did you make them up yourself or buy them?
1989 Mk3 Reimo Camper
1980 Mk2 Holdsworth Camper
ColinJack
Postby FEEZ92 » Mon Feb 04, 2013 4:01 pm
I bought the copper pipe and cut it to length to fit between the injectors and I soldered in a smaller 4mm pipe into the pipe for no.4 injector to connect to the original fuel system.
ColinJack wrote:Cool copper link pipes on those yellow spots. Did you make them up yourself or buy them?
MORE BOOST!
MORE SMOKE!
FEEZ92
Postby ColinJack » Mon Feb 04, 2013 4:08 pm
FEEZ92 wrote:I bought the copper pipe and cut it to length to fit between the injectors and I soldered in a smaller 4mm pipe into the pipe for no.4 injector to connect to the original fuel system.
Looks really good. As long as you don't blow the whole thing up in the meantime :lol:
Loving this project ... totally mad!
ColinJack
Postby FEEZ92 » Mon Feb 04, 2013 4:28 pm
Hi erling
I have reached 6000 on the Di (see one of the earlier videos int the thread)
I love the mercedes engines because they are very easy to get power from :)
On the Di injectors, there are 5 very tiny holes and they are very restrictive when you try to increase fuel volume per stroke. The "yellow spot" injectors have larger holes so they pass more fuel for the same fuel pressure. This is the main difference between injection systems and tuning Di and IDI engines, the IDI injector has only one big hole and can pass more volume of fuel with less pressure increase.
The exhaust clears to light grey smoke when on boost, I'm hoping it will clear up completely when the Intercooler is fitted. Not the Citroen one, but a universal aluminium intercooler which I will be fitting this week.
I was looking at the Mercedes M45 supercharger for the van, from the W203 petrol, do you think this will be ok to provide enough boost to give some useful torque in the low rev range?
Any advice is greatly appreciated :)
erling66 wrote:Hi
I like your project :D My experience is with Mercedes IDI engines so I am quite new to DI engines. On a IDI engine 6000+ rpm is no problem :lol: but I will be surprised if you reach 6000 on the DI. ON the Mercedes IDI we never have to change injectors, the stock ones are good for 100hp+ each :D I see that you are always talking about changing injectors so I guess the stock ones are quite restrictive :?
I have a few questions I hope you have time to answer: Does the exhaust clear up when you get boost(any video of your exhaust while driving)? Did you feel some difference with the new injectors? What boost are you running and at what rpm?
Did you install the Citroen IC?
I can try to help you with info on superchargers if you are interested :)
MORE BOOST!
MORE SMOKE!
FEEZ92
Postby FEEZ92 » Mon Feb 04, 2013 4:29 pm
Thanks, that's why I have spares lol
MORE BOOST!
MORE SMOKE!
FEEZ92
Postby James1123 » Tue Feb 05, 2013 10:15 pm
Feez what intercooler are you going for up front?? what sort of size? any thoughts on pipe work?
I like the look of silicone hoses for the turbo air pipes, any thoughts?
2000 MK5 SWB Semi Hi-Top 76ps TDI
James1123
Postby erling66 » Tue Feb 05, 2013 11:48 pm
Hi
I consider the Mercedes M45 supercharger too small for a 2,5 DI. your engine use ca 1 liter of air pr turn and the M45 gives 0,67L so if you run it twice as fast as the engine, you will have some boost but not much. So the M62 is a better choice.
You have left to right: M90, M62 and M45(all Eaton).
The M62 on the photo has an electric clutch so that would be a perfect choice. Mercedes and others used it so It should be possible to find used.
I mostly work with the 3.0L mercedes IDI engines and almost everyone use the M90 and run it 2 twice as fast as the engine. That gives ca 0,8-1 bar boost from 1000rpm and up.
There are many other types of superchargers available but often they are very expensive or does not work as well, so most people use the used Eaton M45-M112 superchargers.
To run a supercharger together with a turbo on a diesel engine works quite well but it is a little complicated to hook it up so people only do it if they want a lot of HP or they like the challenge to see if they can make it work.
Different topic: Has anyone tried to drill larger holes in the DI injectors to make them flow more?
erling66
Postby IgorVigor » Thu Apr 04, 2013 10:17 am
the Injector holes are precision drilled so its not a good idea to open them up....
the spray pattern of a Di injector is VERY important!
the 100ps injectors will flow enough for 22psi and 360~380cfm at 4,500rpm....
thats still with a nice smoke haze :)
anything more than that, and the marine injectors will be needed (still need to get a set for my transit at some point....)
Got a couple of turbo choices for mine :twisted:
IgorVigor
Postby FEEZ92 » Sun Apr 07, 2013 11:28 am
Yeah you can't modify injector holes without specialized equipment. They are extremely tiny, narrower than a hair.
I got an M45 supercharger, it might go better on my W202 Diesel.
Some pics:
MORE BOOST!
MORE SMOKE!
FEEZ92
Postby oldyellar » Sun Apr 07, 2013 12:13 pm
thats cool as fek 8) needs a modded mk4 grill now :wink:
oldyellar
Postby FEEZ92 » Wed May 01, 2013 8:19 pm
Diff has disintegrated so time to get the welder out I guess :-)
MORE BOOST!
MORE SMOKE!
FEEZ92
Postby IgorVigor » Thu May 02, 2013 10:50 pm
FEEZ92 wrote:Diff has disintegrated so time to get the welder out I guess :-)
How did you manage to kill the diff? :shock: :?
IgorVigor
Postby FEEZ92 » Thu May 02, 2013 10:59 pm
From doing too much burnouts I guess.
With one wheel spinning it put a lot of stress on the planet gears inside the diff. Also the oil was as thick as grease which obviously didn't help. One of the planet gears broke up and jammed the rest of the operation.......
I welded up the diff today. Pics to follow.......
MORE BOOST!
MORE SMOKE!
FEEZ92
Welding the Diff
Postby FEEZ92 » Fri May 03, 2013 2:29 pm
MORE BOOST!
MORE SMOKE!
FEEZ92
Postby robbie.cee » Fri May 03, 2013 10:50 pm
so it was professionally vandalised then!! :lol:
in the last picture, what was it you welded up Feez?
i heard people say the welded up the diff to lock it, but which bits are you locking together?
top thread m8 ! 8)
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
