AlanN's MK3 V6 Day Van
Re: AlanN's MK3 V6 Day Van
Postby AlanN » Mon Dec 24, 2012 11:36 pm
BROWNYS V6 wrote:left the van :shock: park n ride :shock: fookin ell ya mad :?
glad you got it home safe :) well done tony :wink:
I was going to get AA relayed, but it was quicker to go on the tour, go down the pub afterwards and come back later with a fresh head...
Postby BROWNYS V6 » Mon Dec 24, 2012 11:54 pm
brave man :wink: would'nt ave left my van, good job on getting it home :)
BROWNYS V6
Postby MinorMatt » Tue Dec 25, 2012 12:53 am
Winchester is a nice sedate, civilised place. I wouldn't have been worried about leaving alans van there :lol:
What went wrong with it?
Postby AlanN » Tue Dec 25, 2012 1:47 am
Water must of been getting the main unit inside the bulkhead!!! Alarm just went haywire!!!, looks like Im going to be having another look tomorrow, well it is my day off, sorry thats today
Postby robbie.cee » Tue Dec 25, 2012 12:46 pm
Not good man, not rain bouncing into air vent on scuttle panel is it?
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby AlanN » Tue Dec 25, 2012 2:08 pm
I had the glove box out and all the sound proofing and I did find a little water sitting on top of the alarm! so that could be the problem, but I couldnt work out where it was coming from, maybe from the bolts holding it to the bulkhead panel. Weather hasnt been too good to even get out there and have another look, even after all this time, I still dont have any switching power to the fuel pump relay, even though I have bypassed the alarm feed... Needs a a nice day to get out there pull the wiring out :roll:
Postby robbie.cee » Tue Dec 25, 2012 2:22 pm
I'd run extension lead out, take heater out too and get busy,
Tv will be crap as usual LOL
Had
MAKE IT FIT
robbie.cee
Postby transit mark » Wed Dec 26, 2012 7:45 pm
Im with robbie. While replaceing the matrix on mine i had the extention lead with light and heater.
2001 MK6 90PS MWB RWD
transit mark
Postby AlanN » Thu Dec 27, 2012 6:26 pm
I need the doors open, so heater wont be much help :lol: I'll get around to it soon, just eating too many minch pies at the moment :roll: :lol:
Postby blue estate » Thu Dec 27, 2012 6:29 pm
AlanN wrote:I need the doors open, so heater wont be much help :lol: I'll get around to it soon, just eating too many minch pies at the moment :roll: :lol:
And to many tinnies as well
What's a minch pie?
blue estate
Postby AlanN » Thu Dec 27, 2012 6:35 pm
you could be right :lol: :lol: :lol:
Postby robbie.cee » Thu Dec 27, 2012 6:58 pm
1200w 3 bar infra red heater from market- the heat dont blow away!! :wink:
Had
MAKE IT FIT
robbie.cee
Postby ColinJack » Sun Dec 30, 2012 7:58 pm
AlanN wrote:I had the glove box out and all the sound proofing and I did find a little water sitting on top of the alarm! so that could be the problem, but I couldnt work out where it was coming from, maybe from the bolts holding it to the bulkhead panel. Weather hasnt been too good to even get out there and have another look, even after all this time, I still dont have any switching power to the fuel pump relay, even though I have bypassed the alarm feed... Needs a a nice day to get out there pull the wiring out :roll:
We are all on tenterhooks waiting to see what happened next. This is like Panto (look out behind you!) :lol:
1989 Mk3 Reimo Camper
1980 Mk2 Holdsworth Camper
ColinJack
Postby AlanN » Sun Dec 30, 2012 8:57 pm
Ive had a little look today, alarm seems to be working as normal now, so I reckon it got wet via the bolts through the bulkhead, so I'm going to sort that when I get a chance, maybe move the sounder to another place, out of sight and extend the wiring and weld the holes up. But I still cant work out why the fuel pump relay wont switch with ignition, fitted new relays etc. but nothing, so Ive now got to look at the ignition switch, but I didn't have time to strip the column and clocks out to check.
Washed the van for the first time since Southampton, its a mess underneath and all the ali parts have corroded due to road salt, its a good job its all comming out in the spring to do gearbox. So that will be a good time to get my new employer BCW to strip & paint engine bay and to make my new exhausts, mounts, brake lines etc. while I refurbish engine 8)
Postby ColinJack » Sun Dec 30, 2012 9:27 pm
AlanN wrote:Ive had a little look today, alarm seems to be working as normal now, so I reckon it got wet via the bolts through the bulkhead, so I'm going to sort that when I get a chance, maybe move the sounder to another place, out of sight and extend the wiring and weld the holes up. But I still cant work out why the fuel pump relay wont switch with ignition, fitted new relays etc. but nothing, so Ive now got to look at the ignition switch, but I didn't have time to strip the column and clocks out to check.
Sounds good - your engine bay was pretty pristine before! :lol:
ColinJack
