69 Flower Power Hippie/Hotrod Transit
Re: 69 Flower Power Hippie/Hotrod Transit
Postby noah » Sun Jul 31, 2011 7:29 pm
good work there.............................
noah
Postby pat stevens » Mon Aug 01, 2011 9:35 pm
just came across this thread nice work keep the pics comming
if its got tits or wheels its always gonna end in trouble !!!
anyone can restore a van but it takes a real man to chop it up !!!
pat stevens
Postby mr Grimly » Tue Aug 02, 2011 12:30 pm
another one saved !!! :D
mr Grimly
Postby Franfixit » Thu Aug 18, 2011 10:54 am
Finally...back at it....
Radiator/condenser and thermo fan mounted...battery tray went away...still don't know whether it will be back. Engine is out again, next up is fitting a MK2 booster/master cylinder...looks to me like the firewall needs to be a different shape :wink:
If you didn't build it yourself...It isn't really yours (Tim the Toolman Taylor)
Franfixit
Postby Franfixit » Wed Aug 24, 2011 12:50 pm
Only got one of my days off to work on van this week because of relatives visiting, but things went easier than I had expected....
I clearanced top of Mk 2 pedal assembly so that it could sit over top of Mk 1 column and bolt to underneath of dash
Then I fitted a piece of Mk2 firewall (with booster bracket outline) to the front of pedal box and cut a peep hole in Mk 1 firewall
...followed the bracket outline on the Mk 2 piece to cut out the Mk 1 firewall
Hit the Mk 1 firewall with a hammer....repeatedly :) until it contacted the Mk 2 piece...Cut Mk 2 piece to close fit and welded..Firewall 'adjustment' altered position of hole for steering column considerably so that rubber boot wouldn't go on...prepared to relocate said hole
Column hole relocated
Franfixit
Postby deankdx » Wed Aug 24, 2011 1:10 pm
good work.. i did't know they were so different
1980 Mk2 4.1 litre 5 speed manual, 2.77 or 2.92 falcon diff conversion, falcon front discs.
project thread herer viewtopic.php?f=27&t=24731&start=60
deankdx
Postby rover » Wed Aug 24, 2011 1:10 pm
Nice work :D
Can't wait to see what this will look like!
rover
Postby transitandy » Wed Aug 24, 2011 11:02 pm
rover wrote:Nice work :D
x2 8)
Postby gravelrash2004 » Tue Aug 30, 2011 9:41 am
There is some fabulous work being done here. VERY IMPRESSED
with you skills as a welder have you ever considered a Mk5 :lol:
My Projects
150S :- DOHC 2.0 EFI (115PS), Ratio: 5.14
viewtopic.php?f=27&t=66682&start=15
viewtopic.php?f=27&t=97579&p=829640#p829640
gravelrash2004
Postby Franfixit » Tue Aug 30, 2011 10:15 am
gravelrash2004 wrote:There is some fabulous work being done here. VERY IMPRESSED
I hadn't imagined the later model Transit's being quite as rusty...as.....well ....as you've demonstrated they can be......a Mk 5?.....I know to be afraid....Be very, very afraid!!
Franfixit
Postby Franfixit » Thu Sep 01, 2011 12:44 pm
Crossmember almost done....Pretty sure it'd hold a Kenworth engine now :lol:
Finished firewall welding, Brake booster mounted..Hooked up Mk2 brakelines as a temporary measure.
Franfixit
Postby Franfixit » Wed Sep 28, 2011 12:58 am
Finally got around to airbrushing welding mask how I imagined it :D A friend of mine who's done a fair bit of hot rod building checked out my crosssmember and pointed out some places where an engineer would want some gusset plates/bracing..So a little more work on the crossmember...but it's completely finished now ,so time for a different game....................
I've fabricated an oil pick up extension pipe..you can see from where the oil pump is that the pick up was much further forward and it's depth projection was much less....Of course it lined up with the beam axle..hence the mod..Rather than just discreetly relocating the pick up in a conservative way..I have decided that while I am at it, one of those race style oil pans would be cool.
Franfixit
Postby deankdx » Wed Sep 28, 2011 9:52 am
10 litre sump to combat the oil leaks.. good idea :)
deankdx
Postby Franfixit » Thu Sep 29, 2011 12:06 am
deankdx wrote:10 litre sump to combat the oil leaks.. good idea :)
I had a Valiant wagon that would have been great for...I was travelling 400km per week and it was using about 4 litres..got to the stage where I had to pull the spark plugs out and clean them with a toothbrush after each trip to and from work...otherwise it wouldn't start.
Franfixit
Postby MinorMatt » Thu Sep 29, 2011 9:45 am
At one point in my minor i was losing about a litre every 5 miles (8km) :shock:
