I have been noticing a grind/scrape type noise during the first mile or so of driving especially when the van hasn’t had time to warm up. It happens when either slowing down or when speeding up usually when gearing up and down(from memory second to third-third to second). I have been listening out for it and I believe it’s the axle/diff. Gear change is good and as smooth as one would expect for the year.
Playing on my mind a bit to the point I was awake last night worrying about it. So after a little read on the forum and Haynes I popped to Halfords for some fluid. Before I did I got my carcass underneath the van and undid the plug. I wanted to eliminate the thought of having no oil in there at all…there was, but the amount I had was well below the plug level.
So off to Halfords I went as well as getting a quick grocery shop in!!
I bought a litre for now to top up. The idea is to top up and see how it goes. If all fails I would get a gasket and take the back off for a better look…I have a leak from the seal and my intention is to rectify it. I must point out it’s not a noticeable on the floor leak. It looks like it has been like it for a while. I should have taken care of it when I treated the gearbox to new oil!! I couldn’t get a gasket locally so have to get one from EBay.
Here is the oil I bought, only a £1 dearer than Halfords GL5.
Got this Allen key and it fits a treat, yet to work out its size. I think it’s 10mm
Here is the top up plug. When I undid it and had a look I was convinced the plug had a magnetic end. The reason being I had small what would be described as filings shaped like a very small Christmas tree. I have learned this is normal for wear and tear. (Some gearboxes have them) However, if sludge deposits were surrounding the plug there is a strong indication the pinion bearing etc. is knackered or most certainly on its way out!
A picture of the back showing the leak which I plan to sort out once I get the gasket sorted. It is the only leak I have. Pinion seal is showing no signs of leaks.
I have topped the diff/axle up and it took 750ml before dribbling out which came as a shock as about 1.5ltrs is recommended. Basically the diff was operating half empty (or half full depending on your philosophy) what damage has been done as its slowly leaked over a given time is a question I’m unable to answer. I am hoping none. If I have to overhaul the bearings and change the pinion etc then I will opt for swapping everything for a taller ratio 4.63 (Currently 5.14).
First things first though, see how things pan out with the top up done.
