69 Flower Power Hippie/Hotrod Transit
Re: 69 Flower Power Hippie/Hotrod Transit
Postby gravelrash2004 » Tue Dec 13, 2011 1:21 am
Need.................more........progress.................report.........
:lol: :lol: :lol:
Loving the work on this
My Projects
150S :- DOHC 2.0 EFI (115PS), Ratio: 5.14
viewtopic.php?f=27&t=66682&start=15
viewtopic.php?f=27&t=97579&p=829640#p829640
gravelrash2004
Postby Franfixit » Wed Dec 14, 2011 12:44 pm
gravelrash2004 wrote:Need.................more........progress.................report.........
:lol: :lol: :lol:
Been........................very................slack.........................at..................posting :lol:
But haven't backed off Bus progress :) .............
Engine in place.........Now what else to blow this carport scene?
That's how much too long the Mk 2 tailshaft was
This is a much anticipated sight............
......and this .....even more anticipated :) ....too impatient to wait for a gear shifter so crawling under the car to select a gear was all the go at this stage :lol:
If you didn't build it yourself...It isn't really yours (Tim the Toolman Taylor)
Franfixit
Postby Franfixit » Wed Dec 14, 2011 1:05 pm
Cleaned the dust off...First time we've seen the True Blue out in the Sunlight...........Pretty :D
Back in the carport.....Chassis crossmember locations marked out so as not to foul shifter
Handbrake bracket removal............and I've just noticed it's 10pm.....So no more pics for now.
Franfixit
Postby Altransit » Wed Dec 14, 2011 1:09 pm
Top stuff :!: 8) :D
Postby deankdx » Wed Dec 14, 2011 2:25 pm
will be finished before mine at this rate. great progress!
1980 Mk2 4.1 litre 5 speed manual, 2.77 or 2.92 falcon diff conversion, falcon front discs.
project thread herer viewtopic.php?f=27&t=24731&start=60
deankdx
Postby pat stevens » Wed Dec 14, 2011 8:15 pm
this is going at a great pace well done lovin'it
if its got tits or wheels its always gonna end in trouble !!!
anyone can restore a van but it takes a real man to chop it up !!!
pat stevens
Postby gravelrash2004 » Tue Dec 20, 2011 3:20 am
Me likey!!!!
(jumps up and down like an excited puppy)
:lol: :lol:
My Projects
gravelrash2004
Postby Franfixit » Tue Dec 27, 2011 12:03 am
One shifter..too wide to fit between seats
So chopping time
Goes for this bit too
Shaped it a bit with the 'lathe'......angle grinder :lol:
Some new thread on the round bit
Though seemingly unprofound...it's now relevantly narrower for fitting
Change of lever angle...too lazy to weld fill,drill/cut and file.....so I just rotated the fitting point
Shifter set up at raw, crude concept state
....fits between seats now
Solid linkage shift mechanism menagerie
Linkage set up reversed linkage travel direction so it had to be fitted below pivot point on gearbox....factory attachment point would have been an unworkable angle so I added a bracket to change that
Franfixit
Postby BROWNYS V6 » Tue Dec 27, 2011 12:12 am
top work 8)
BROWNYS V6
Postby transitandy » Tue Dec 27, 2011 12:21 am
great work 8) 8) :)
Postby gravelrash2004 » Tue Dec 27, 2011 12:22 pm
This is truly TOP WORK! Makes me wish my lady was as good with a spanner and tools.....
maybe not then she may just tidy my tools away for me and i couldnt find anything again :)
My Projects
gravelrash2004
Postby pat stevens » Wed Dec 28, 2011 7:21 pm
know exacyly what u mean ,its the kids in my house lol
first class work going on here as usual well done
pat stevens
Postby Franfixit » Tue Jan 10, 2012 9:30 pm
Now I don't think I ever mentioned it but the big side passenger door pillar was somewhat damaged....so I removed it ( I did post an engine shot that showed the pillar missing).....Transplanting a Mk2 pillar and the hinge locations are different so here's the Mk2 to Mk1 pillar conversion.......
Here's the plates that lurk behind the pillar skin....plus fill ins that I have cut out
I extended the factory plates with some steel sheet....so when in their new location the old holes have a backing plate in place for my fill ins
Welding in the fill ins
Minor rust repair
Out with the reofill.....seems I missed a step in the pics....the filler on the side of the pillar (Hey that rhymed) is where the internal structural thingy for the door hinges was relocated and plug welded in place
Etch primed........Slight interuption in pillar work as Toni wanted to do stuff on rear doors and they needed hot work first......Did a whole bunch of edge repairs....Just showing the one...........
........and that's one repair..layer by layer
Franfixit
Postby Franfixit » Tue Jan 10, 2012 9:48 pm
Sort of forgot to weld this door retainer thingy in place.....Well I remembered as I was prepping for the etch primer but with limited time before going to work I decided to seal the bare steel and come back to welding this in
Onto the job...all plug welds replacing the original spot welds......
..........except for the door jamb side that tacked butt weld style then swiss cheesed.....
.....and weld overlapped with a 2mm thick backing plate plug welded in place
Door in place on new pillar
Franfixit
Postby Franfixit » Tue Jan 10, 2012 10:10 pm
And now onto something different.....this is all about a certain crossmember that I removed because the bell housing occupies the place where it was.......
Floor coming out
Weeding the unwanted bits off a donour crossmember....this is a full blown Transit crossmember as found behind the drivers seat...not like the skinny one I cut out that is forward of the front seats
Franfixit
