Rob Cee's transit - start of makeover
Re: Rob Cee's transit - start of makeover
Postby robbie.cee » Mon May 06, 2013 3:13 pm
Ron mate you are a diamond! Nice one
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby robbie.cee » Tue May 07, 2013 6:53 pm
Had to catch up on some sleep today so i rang in sick... got up about 2 pm feeling a bit more energetic.. got the flange fitted up on the o/s head today!
b*stard awkward job but so worth the aggro!!
worked so well ill be doing same on other side some time soon!
not the best shots but heres another
there is a stud i need to replace so only 5 nuts on but still very very quiet
so scimiter manifolds have a use after all! :D
Had
MAKE IT FIT
robbie.cee
Postby jonochap » Tue May 07, 2013 7:01 pm
It just amazes me how you work these things out mate! Are you at b-bridge next week??? Be great to catch up :)
Owner of not so troubled puk :)
jonochap
Postby robbie.cee » Tue May 07, 2013 7:23 pm
er not sure bout battles bridge, what is the date dude?
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Tue May 07, 2013 9:14 pm
Think i might also have a cracked HT lead on #3 cos i wiggled it and it smoothed out the idle... will keep an eye on that one! :D
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Wed May 08, 2013 12:24 pm
Still awaiting this leccy pas pump... free postage so it'll prob take ages...
Actually quite excited to see how much power it can produce as technically it came off a small ish car... still i only need some assistance dont necessarily need full Di pas just a bit more help than none at all.. plus if i can keep the extra free'd up horses itll be a result!
was thinking on the wiring... i selected the particlar pas pump because it looks to only have 2 wires and so would be constant runner with engine on. that means it wont overheat or owt.
secondly i can either have a switched relay feed to it so i dont flatten battery in traffic if cooling fans kick in too and also it dont need to be on all the time especially if going in a straight line like motorways or drag strip!
could even add a few diodes and take feeds from reverse lights and indicators (via capacitors) to turn it on automatically... still more to go wrong tho!! :(
need to see Tim to get my new panels soon too, will have a go at fitting em meself in our new house, can put the huge gazeebo from transitmania up as the gardens so big!!! :D
Had
MAKE IT FIT
robbie.cee
Postby MinorMatt » Wed May 08, 2013 6:43 pm
Im sure with a little bit of thought you could make a device that will cut out the PAS above say 20mph? Not sure how off the top of my head but im sure someone can think of something?
Postby hornhead » Wed May 08, 2013 9:30 pm
i have a speed related pinto mod i haven't got round to :roll:
was thinking tiny dc model motor with aeroplane prop under crossmember...
output through variable resistor to base of transistor then to relay and back emf diode
:idea: you could smooth it with capacitor so it wasn't jumping on and off at set threshold
hornhead
Postby robbie.cee » Thu May 09, 2013 9:35 pm
or better still a throttle postion sensor basterdised from a focus or bmw be good, or a linear potentiometer attached to throttle cable...
a switch will suffice me, might bling it up with an illuminated one :lol:
better still, get into dash and use abs light or another unused one! :D :D
Had
MAKE IT FIT
robbie.cee
Postby MinorMatt » Thu May 09, 2013 9:44 pm
remember the MOT rules have changed Robbie and the dash lights all need to function correctly!
Postby robbie.cee » Thu May 09, 2013 9:57 pm
MinorMatt wrote:remember the MOT rules have changed Robbie and the dash lights all need to function correctly!
IN that case an illuminated switch will do! :D
Had
MAKE IT FIT
robbie.cee
Postby captain hook » Thu May 09, 2013 10:03 pm
Any modifications to the steering invalidates your insurance and is a MOT Fail....
captain hook
Postby robbie.cee » Thu May 09, 2013 10:11 pm
captain hook wrote:Any modifications to the steering invalidates your insurance and is a MOT Fail....
lol well i wont tell!
so the insurance is invalid if your belt snaps on the motorway ??
surely a replacement pump wouldnt matter?
Had
MAKE IT FIT
robbie.cee
Postby captain hook » Thu May 09, 2013 10:26 pm
Yeah....That's the attitude with your wife and child in the van :roll:
captain hook
Postby robbie.cee » Thu May 09, 2013 10:32 pm
well still not yet with them in the van... defo not with blowing exhaust too... still got other side to do yet...
and how is it dangerous to put in a leccy pas pump when the factory one dont work?
if i wasnt bothered bout my lil un and wife we would have been out and about in van as it is, yet its been parked up for over 6 or more weeks!
Had
MAKE IT FIT
robbie.cee
