Puk, a troublesome fairy!
Re: Puk, a troublesome fairy!
Postby whitemice » Thu May 26, 2016 11:27 pm
https://www.youtube.com/watch?v=jIaGWURONRU
'' VOTE Kim Jong Unwell.
Mike writ '' a vote for lABOUR is a vote for islam and a conservative vote is a vote for islam and a vote for liberal is a vote for islam. ''
DBVM ''a vote for UKIP is a vote for islam''
whitemice
Location: normalised heavily chemtrailed cretinous individual just like you
Postby jonochap » Fri May 27, 2016 7:51 am
Nice shout for some one but an old head again :(
Owner of not so troubled puk :)
jonochap
Postby jonochap » Fri May 27, 2016 8:02 am
DodgeRover wrote:Has anybody seen the lack of space under PUKs bonnet?
Stick one of the cheap valve lube kits on it or use an additive to save the valves and just enjoy the ride.
Had a look and like the idea of the lube kit as it takes some of the guesswork out, has anyone ever used one? Is the liquid they sell with it the right stuff and can you tee in or do you have to drill a hole into the carb?
jonochap
Postby robbie.cee » Fri May 27, 2016 11:14 am
Prob attach via vac pipe perhaps?
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby MinorMatt » Fri May 27, 2016 12:55 pm
Just put a 2L zetec engine in? Same gearbox bolt pattern as the pinto - its just the electronics to worry about
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby walt1984 » Fri May 27, 2016 2:02 pm
Probably plenty of rwd accessories for when they are fitted to mk1/2 escorts. They can run on carbs too
Sent from my P330X using Tapatalk
"due to ever increasing work load the light at the end of the tunnel has been turned off!"
walt1984
Postby jonochap » Fri May 27, 2016 4:40 pm
I love you guys so much!
The pinto bottom end is non negotiable, sorry. Looking out for good injection head to redo and very interested in the line kit...hate the dosing through a tank thing, too much trial and error for me :)
jonochap
Postby camper extraudinair » Sun May 29, 2016 7:41 pm
Just stick a dirty great v8 from an old yank with points ignition & a carb.
Hi Chaps sorry it's been so long since i contacted you but i have had so
much to do over the last eighteen months since we moved down south.
I have missed you all very much & when i have finished all the work i
have got to finish i will probably be to old to drive "hopefully not"
I took eve to an m o t station down here & she failed on things i new
about. The headlight main beam warning light & rear fog warning light
did not work so i fitted l e d lights blue & red respecktively.
Hope to catch up with you in the near future love to all Raymondo.
camper extraudinair
Postby DodgeRover » Mon May 30, 2016 9:31 pm
I've got a vacuum based drip feed one (that I never got round to fitting) and the other halfs car runs a posh electronic one.
Given your luck with things i would go for the electronic one as theres less chance of it randomly dumping its contents into the inlet manifold while the engine is turned off just to be awkward.
Couple of links
Posh one
http://tinleytech.co.uk/shop/valve-savers-and-fluids/flashlube-electronic-valve-saver-kit-e2/
Cheap one
http://tinleytech.co.uk/shop/valve-savers-and-fluids/flashlube-valve-saver-system-s2/
and
http://tinleytech.co.uk/shop/valve-savers-and-fluids/flashlube-valve-saver-system-1/
The valve saver fluid is about £17 a litre, i think we go through about 2l every 10,000 miles with the Lexus
DodgeRover
Postby jonochap » Mon May 30, 2016 10:40 pm
camper extraudinair wrote:Just stick a dirty great v8 from an old yank with points ignition & a carb.
CE! So good to hear you're still about, the one meet we managed still pops out a piccy every so often!! Hope the mot goes well and I'm sure you'll be driving for a while yet, afraid that starting handle alone frightens me so no v8 for me!! :)
jonochap
Postby jonochap » Mon May 30, 2016 10:46 pm
Thanks ever so dodge, hope you're wrong as I went for an lpg shop one from e bay, no electric but gravity...I have a spare pipe connector on the same tree as the brake servo, is it okay to use that for the incoming? That would put the tank in a good place too. I think I'll be lucky to get 2 l to 10000!! :)
jonochap
Postby DodgeRover » Mon May 30, 2016 11:04 pm
Just have a good read of the instructions :) if it's the same as mine they are pretty simple to set up, they use manifold vacuum to regulate the flow of valvesaver.
Unless we have some unexpectedly strong gravity there isn't too much to go wrong
DodgeRover
Postby jonochap » Mon May 30, 2016 11:08 pm
Instructions?? Yip, I see nothing that could end in total and complete destruction!! :)
jonochap
Postby jonochap » Sat Jun 04, 2016 6:22 pm
Typically no instructions included, it now looks like this...
Just a bit Heath Robinson but seems to be working, still a bit pinky but gonna try different gogo juices now
jonochap
Postby DodgeRover » Sat Jun 04, 2016 9:54 pm
It shouldn't be pinking, retard the ignition timing before it eats it self again
DodgeRover
