bez's mk5
Re: bez's mk5
Postby oldyellar » Wed Feb 27, 2013 10:54 pm
oldyellar
Re: bez's mk5
Postby bez » Mon Mar 18, 2013 10:42 pm
well boost now up to 20psi need more fuel so ill get some 130bhp injectors now
if in doubt flat out!
bez
Cosworth Powered
Cosworth Powered
Re: bez's mk5
Postby bondyfnm » Tue Mar 19, 2013 9:41 pm
Does that mean it will kick out 130 bhp?
Whats the most a 2.5 di will manage?
MK5 lwb 190 hi top
MK5 swb 100 project
MK1 capri project
bondyfnm
Re: bez's mk5
Postby MinorMatt » Tue Mar 19, 2013 10:17 pm
depends how much smoke you can live with...
Without an intercooler, with the standard turbo - but wound up... simple online calcs and 1/4 mile times suggest mine was putting out 115 - 120hp at North Weald last year. I am hoping to be at about 150 this year
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Re: bez's mk5
Postby bez » Tue Mar 19, 2013 10:33 pm
I'd like to no what mines running iv got a turbo off a 5cyl audio and a big fmic,metering pin removed fuel upped and shimed govener 3mm.egt is 400 degree.and it goes mad on boost can't believe difference its made
bez
Cosworth Powered
Cosworth Powered
Re: bez's mk5
Postby bez » Tue Aug 29, 2017 11:12 pm
She still going strong needs some new wings now thi :D
bez
Cosworth Powered
Cosworth Powered
